I want to experiment with putting bar end shifters and brake levers on my converted road bike. I presently have it set up with pursuit bars, aero bars and sti shifters on the base bars. Not sure what brake levers to go with.
Is the Dia Comp 188 the only brake lever available with outside cable routing? If I go to Syntace Space Control levers which I understand are internal routing, I assume I need a new base bar with holes drilled for the exit right? I assume it would be a bad idea to drill holes in Profile Design bars? Thanks!!
