Is it possible to retrofit shimano-compatible brake shoes onto campag brake calipers? I want to run shimano compatible pads on my campag brakes.
bump
You can put any pad on campy brakes that you want. You only are glued to campy pads if you want to insert them into campy holders. You cannot put shimano compatible insert into campy holders (or the other way around) but you can bolt different holders onto campy brakes.
"You can put any pad on campy brakes that you want. You only are glued to campy pads if you want to insert them into campy holders. You cannot put shimano compatible insert into campy holders (or the other way around) but you can bolt different holders onto campy brakes. "
Not really. The campy brake shoes have a different diameter post from the Shimano (and everybody else) standard; they have a slightly larger OD. you can make it work, but non-Campy pads have a tendency to slip if you don’t sleeve or shim them.
