Question for Tom Demmerly
Tom, I posted the other day “My New Ride” http://forum.slowtwitch.com/gforum.cgi?post=248270;search_string=my%20new%20ride;#248270 and was wondering if you have have any suggestions on clip on aero bars. I am rather new to the sport of triathlons, but I have been an avid biker for over 20 years. I was looking at your post on the vision tech shorties for 69.00 but after reading your thoughts on them they may be a little short for me at 6’3". Would it be best to call you/or someone else at your shop and order them over the phone? Thanks
I’m not Tom, but I’d be willing to bet that small size Syntace C2’s would work very good for you on that bike. They’re still a little longer than the shorty bars but not long enough to make you feel too stretched out in a road position/geometry. They are also the standard for comfort IMO.
Thanks, I have heard nothing but good things about Syntace and their products. My dilemma is (as you have touched upon when you mentioned comfort in Road position) that I did not want to buy a tri specific bike, because I will spend the majority of my time riding with friends, secondly in training rides by myself and last, but not least, in Triathlon races. I am not sure if this is the case with everyone, but it is certainly is with me that whenever I am in the mood to really crank it seems to always pull me forward in the saddle even with out the bars (Probably a bad habit!). This is why I have no ideal what size to get or models to look at! Ahhhhhh…the choices we just have to make! :slight_smile:
" did not want to buy a tri specific bike"
You might also want to look at the “big slam” position on a road bike. Essentially it is sliding your saddle back a bit and lowering it slightly while using shorty aero bars. Seems to work very well for some people, especially tall long femur types.
http://www.bicyclesports.com/Slam_Setup.html
Just a personal recommendation - Oval ‘slam’ bars. I’m 6’3" and went from a KM40 w/Syntace to a road bike with the Ovals, and they gave me a very comfortable position. YMMV
Cheers
Barry
Hi, if your interested in the Oval ‘slam’ bars, PM me. I have a set I will set for cheap ($25 + shipping).
Dave from VA
cerveloguy’s recommendation is one I can strongly second for the reasons he pointed out.
Also, the risers or elbow pads (whichever you like to call them) are slightly higher on the Syntace. Some people like that, some don’t. But I wager in your circumstance that you might enjoy the higher pads- especially at first.
Good luck!
Ok…you and cerveloguy have talked me into into the Syntace C2’s, I would have never thought the small size would be best, but hey that is why I better not quit my day job…how much are they and where do I call to buy them? Do I call your store and ask for you, or anybody can help me? Thanks again!
I’m 6’4" and ride a road bike… anyways, I use the oval slam bars (but NOT in the slam position). They work really well. Also the Syntace small C2’s (or maybe their XXS bars?) would work well for you. Just make sure you’re handlebars with a 26.0mm clamp surface for the Syntace.
Sweet new ride!
thanks for the advice about the clamp size. I checked out my bike and sure enough the bars/stem are 31.7 not 26. I went to the Syntace website and they said they have an adapter called a 318 kit that will work with 31.8 handlebars. I would assume that 31.7 and 31.8 is not enough to make a difference.
KIF,
I like your bike. Nice touch with the red in the wheels. I’d bet the Leader frames are rolling off the same assembly line as many higher end boutique brands. One suggestion if I may. I know I’m not Tom, but a couple of suggestions regarding positioning. The saddle seems a bit nose-down and might post problems with Aerobars, additioanlly, the amount of headset spacers you have under the stem is a bit excessive. If that stem can be reversed and provide an upward rise realtive to the steerer tube, I’d go that route. I’d almost mandate that change if you are using a carbon steerer tube. I watched a friend take a nice core sample of his thigh Sunday when his steerer tube broke off of the top of the fork, he’s a big bitch at 6’5" and at least 200#s, but he only had 2cm of spacers and an ITM Millenium stem.
This is an honest suggestion. I’m not looking to sell you anything here. Honest.
-SD
Thanks for the compliments and advice…I did mention that in my original post about the spacers under the “My New Ride” thread. I simply do not want to cut the fork height until I get my aero bars and can dial in the proper positon. I think the picture is somewhat of an optical illusion with the seat appearing to be nose down. I thought the same thing when I first looked at it. Again I think I will get dialed in a position when the final pieces come together. Thanks again!
Thanks for the advice you have been a big help…as I had mentioned in my previous post I have been strictly a road rider for years so hang in there on this last question. I was wondering how you go about deciding which size is the best. When I go to the Syntace website they go small, medium, or large and have a riders height for rough comparisons for which one to buy. I like the ideal of the smallest possible, but do you have anymore insight as to how to decide which one is best. I would go to my LBS here, but they only sell Profile Bars. Again I know there are a lot of variables working here about sizing
“do you have anymore insight as to how to decide which one is best.”
For road position with the Syntace C2’s my advice wuld be to go for one size smaller than what is recommended for your height. I would use a medium Syntace C2 in a tri position but when I used this on my road bike it was a bit too big and I felt a bit too stretched out. I found the small size worked perfectly on the road bike. I particularly like the Syntace C2 because I’ve found the bar to be very confortable. I’ve found my other bars I tried on my road bike - Profile Jammer GT and Profile AeroLite to be not as comfortable.
Hope this helps.
