Question for those with Computrainers
2 questions for you guys.
1.) Is it possible to begin a second lap on a course without losing all the stats from the first go around? Right now I restart the course once I finish and lose all the data (speed, watts etc…). I know I could just use a longer course but there are some interesting shorter ones.
2.) Just curious about this one but are the turns on the CT course accurate with the turns on the real course or do they just do that to change the scenery a bit?
Thanks for the help!!
I’m not positive but:
  1. As far as I can tell, no.
  2. Seems to be arbitrary.
-C
Depending o nthe course and how close the start and finish are from each other, you can close the loop and then change the loop counter. This will allow you to do what you want. In most cases the turns are the actual turns on the course, depends on how old the course is.
