trying to figure out hypothetical torque on a rider that can produce 2000 watts in a 53x11!
Can anyone help?
Imagine the rider as a sphere…sorry, that is all I got from my physics classes. Unless you want to talk non-classical physics? In that case I may be able to tell you the rider’s speed OR location (but not both).
Gearing is irrelevant. Power can be computed as torque*angular velocity. You have the value for power (2000W): the torque depends on the cadence. High cadence → low torque, low cadence → high torque.
ok, how about at 145 rpm, what would the torque be?
~132Nm. I think.
2000 * (1/145 * 2pi ) * 60 = 131 N m (avg)
which would be about 169 lbs of force (avg) into 175mm cranks.
I think that’s the right maths and units.
yep…
torque = power/rpm x 60,000/2pi
Well, to give it an eulerian bent, you’ve given us one equation with two unknowns. We can have a lot of fun with this, sincew there are limitless correct answers to this.
Heck I can even make it imaginary…
Say that my torque is 31.62 + 31.627i
and my angular velocity is 31.62 - 31.62i
then my torque x angular velocity is 2000W
Now, if only I can find my imaginary torque =P
(feel free to check my math, i don’t use imaginary numbers at all!)
Don’t forget that would also be the average torque and would assume the rider pedals in perfect circles, which is not the case.
LOL, from a fellow math geek.
As a fellow math nerd (strictly amateur !) I wonder if there are any rough guesstimates out there for wattage in real world terms to compare perfect circles and typical “stomp” patterns of pedalling ?
That’s a Physics question, not Maths!
bahahahhaahha
Just to prove that I learned something in college, real math geeks don’t work with imaginary numbers … they work with complex numbers. If you want to send a math prof tailspinning into nervous breakdown, keep referring to them as imaginary numbers. I’ve seen them nearly at the point of tantrum. Hilarity for the class, therapy for the prof.
