Question for the electronic gadget people?
So I hooked up my new H Def LCD TV this weekend. I have a HDMI cable box but my Sony home theater system is pre HD and there won’t be a new one purchased anytime soon.
So…I hook up the tv to the box and theater system and everything is working fine, but the HD picture ain’t what I’d expected.
I go to Radio Shack to pick up a universal remote and while I’m there I talk to the guy about my setup. He tells me I need a $130 Monster cable to connect my HDMI box to my TV because normal coaxial cables can’t handle HD capacity.
I buy the cable and hook it up and change my signal reception from analog to digital and the picture is better on the HD channels. Only problem is that it now bypasses my home theater system…no surround sound and I can’t play DVDs.
Is there another setup I can try? Should I call the Geek Squad?
Matt,
Welcome to what I call the hidden costs of Hi-Def.
The HD cable box normally costs about $5 more a month too. Pretty soon you’ll be asking yourself is watching TV really worth it?
Bernie
That’s BS. Any HDMI cable should work fine. You can get far cheaper HDMI cables. With the money you save you can get a good upscaling DVD player.
A few points:
Any HDMI cable is fine. I use the Accoustic Research brand at about half the cost of Monster. With HD, you need to make sure that every link in the chain is HD friendly. Are you getting a HD signal? Cable? Does your box and TV have HD settings that have to be configured. My (satelite) box has different resolutions it can output, so be sure yours is set to 1080p (or whatever). Sound. You do not need to use HDMI to deliver sound to your home theater. If you want to take advantage of Dolby 5.1 sound, you will need either digital optical or digital coax. Does your Sony home theater have connections for those? Regardless, you can still route the sound to your home theater and the picture to your tv.
Expensive cables is the first thing they try to sell you. Digital signals are 1’s and 0’s. You either get a signal or you don’t. An expensive cable is not going to make the “quality” of those 1’s and 0’s any better. Try monoprice.com or bluejeanscables for inexpensive and perfectly suitable cables. Monster cables are marked up like 10x over what they’re worth.
Although I agree that Monster cables are overpriced, not all cables are good enough.
A poor quality cable will cause signal loss or degradation. Yes, a digital signal is only 1’s and 0’s, but there is a lot of them going down that cable to make up your video. Drop enough of the bits and the effect will be noticeable.
I make ethernet patch cables and cheap cabling or a poor crimping will definitely affect the signal quality.
All right, I have a cable question for you. Coax. I have a TV cable that runs from the outside of the house to the other end of the house; it is the cable TV input, supplied by Comcast. I have spliced it to run a couple of other TVs off of it, but the RG-59 F connectors were too small for the OD of the cable. It was suggested that the cable is actually RG-6, but the spin-on F connectors I bought seem too small, too (and I don’t want to take off the jury-rigged connectors I have on there now to try 'em). What else could this cable be, and can I get connectors for it? Yes, I need a pair of calipers. Trying to get info on this from Comcast is like trying to get info from your cable company.
Best solution would be a HDMI-capable theater system… but you know that.
To get HDMI video and surround sound, you may be able to connect the HDMI to the TV, but run the coax or optical digital sound through the HTS (does attaching and HDMI cable to the cable box deactivate other outputs?). This would give you HDMI video for TV/Cable and surround for TV/Cable, but doesn’t help the DVD situation.
To also allow for DVD, you can use another (analog) video input on the TV from the HTS that allows the DVD to display (assuming you’re running the DVD player through the HTS), but this has two negatives: 1. no high quality digital video signal when watching DVDs, and 2) you have to switch the video input on the TV when you want to switch from TV to DVD and vice versa.
Other than that, I don’t know what else you can do aside from getting a new HTS that has HDMI out and upconversion from other video formats.
Hi Ken,
The spec and model of the coax cable should be printed on it. What does it say and I will look it up.
Hi Ken,
It should, but it isn’t. Nothing is printed on the outside: I examined about 4 linear feet of it in two places.
