So I’m working on a do it yourself cross bike for the winter and I think I have messed something up upon installing the crankset. It is a Richey Pro standard double that I have paired with a Shimano BB5500 bottom bracket. the problem is there is not enough clearance between the inner chainring and the chainstay. It rubs on the one oddball bolt where the chainring attaches to the crank arm. It sticks out a little, unlike the bolts that attach the chaninring to the spider, which are flush.
So what am I missing? Is there something easy that I am missing or am I gonna need to replace the bottom bracket, cranks or both? Should I just go with a bottom bracket with a 118 mm spindle, even though that should be for a triple? How much clearance is needed between the inner chainring and the chainstay? Here are the details:
Specialized S-Works CX frame (probably a 2001)
Richey Pro Double 53/39 crankset
Shimano BB5500 Octalink bottom bracket w/ 109mm spindle
All other drivetrain components will be 105 9-speed
