A cyclist friend of mine recently started using Powercranks. He’s found them easy to adapt to - in fact, it only took him four rides to get used to them. Considering this, by how much can he expect to improve by PCing?
People who have spent a lot of effort trying to develop an efficient pedal stroke before PC’s will see less benefit than those who haven’t as some of the changes that PC’s cause in everyone are already somewhat present in them. The number of people who can ride them “easily” for a couple of hours in less than a week are probably less than 5% of all users. This doesn’t mean there will not be improvement but, only, that expected improvement will probably be less than seen “typically” and may take longer to achieve.
The fact your friend wasn’t “used to them” on the first ride means there will be some improvement. How much improvement depends on what he or you mean by “used to them” and what kind of racing he does.
Is he a road racer? Can he ride them for 5 hours at race effort and at a cadence of 90-100? Can he ride them in his TT position for an hour at race effort? If not, then there is still room for “substantial” improvement?
Is he a track racer? Can he ride them at a cadence of 180-200 for however long his races last? If not, then there is still room for “substantial” improvement.
If he thinks that just because he is “used to them” in only 4 days that he doesn’t need them, so he stops, then the improvement he can expect is zero.
Tim’s a road racer and after a couple of weeks could ride them for 4 hours at normal cadences (90-100 rpm) without obvious signs of trauma. (Obviously not all race effort because this is the winter.) I think it took longer for us to get used to seeing him freewheel with both feet down. The only thing he can’t do with his PCs is ride in the drops, which I expect you’ll put some spin on… Tim actually takes it as vindication of his pedalling theories:
http://www.perfectcondition.ltd.uk/Articles/Pedalling/LFC%20ideas/LFC%20Notes.htm
With two people I regularly train with having started PCing this winter I’m looking forward to seeing if, with the exponential increases in power output they should get, they’ll be able to give me a kicking next summer…
well, it is now obvious this guy is well above average for PC’ers and his web site explains why. Not many have their own web page devoted to pedaling technique. However, because he can’t ride them in the drops (and also, I suspect, in the aero position) he will still have room for improvement. It will be more subtle in him than in everyone else. This guy should put most of his effort and time this winter to riding in the drops or on the bars. That is where he will see the biggest benefit.
Tim’s a roadie. He doesn’t ride on tri-bars.
He does when he does time trials.
Try again. Tim is a roadie, not a tester, and has a general dislike of TTs. Even on the extremely rare occasions when Tim does ride a TT, he doesn’t use tri-bars.
Then he should ignore the aero bars part of my suggestion.
I look forward to seeing what degree of improvement a person like him actually sees over 6 months to 2 years, assuming he stays with them. I assume he has pre-PC testing data for comparison?
Really? I’d never have thought of that.
I look forward to seeing what degree of improvement a person like him actually sees over 6 months to 2 years, assuming he stays with them. I assume he has pre-PC testing data for comparison? If he can kick my ass on the summer chaingang next year, that’ll be enough for me.
