Has anyone disassembled the Dura Ace ST-9070 levers? How does the hidden button on top of the ST-9070 lever interface with the circuit board in the shifter? Is there a single circuit board that the hood button is wired into along with the shifter switch? Or is there a separate daughter circuit board? If the latter, can you describe the connection between the two boards.
