Question for Bike Experts
May be a dumb question… is it possible to convert a bike from using 700 wheels to 650??
If you aren’t worried about braking, handling, or looks, yah.
What kind of bike? If it is a Zipp, Softride or a couple others you can do it with no issues.
All you need is a hack saw, a welding torch and maybe some epoxy and you would be good to go.
Basically, no.
It is like my contractor always tells me, “anything is possible how much money do you have?”
If you try and convert the 700c Zipp to a 650 you may have rear brake problems. The rear brake mounts under the bottom bracket and has only about 1/2" of adjustment. Although I’ve never tried this, it could be an issue. BTW I just pulled my Zipp brake off my Zipp frame this morning, cleaned it and replaced the cable. It really may not be enough adjustment to reach a 650 rim…then again…if you cut the track dropouts in a little further, it would work?
