I have never used a powermeter but I am stuck working out indoors this week because of the smoke from local forest fires. I went to my new gym and lo and behold they have two “espresso” bikes hooked up with virtual courses and power meters.
I am trying to figure out, purely for my own curiosity, what a “good” power output would be. These machines measure ongoing power output and average output. I managed to hit an average of 204 watts over about a half hour keeping my heart rate around 151. This seemed to tire my legs as much as my 90km ride at RI 70.3 and that ride was pretty good (2:33). Granted there is no slack time on these machines. Downhills aren’t spent coasting, they just get slightly easier.
How can I actually use this data? Should I do workouts and try and keep my power output consistent for maximum benefit? How do I determine the relationship between my heart rate and wattage or power output?
A lot of people know more about power meters than I do but I’ve been using one for two years now. For a 2:30 on a flat 70.3 you probably averaged right around 200 watts. The question is could you have held 200 watts on the machine for 2:30?
As far as a tool I use a watt goal for a lot of my training. I’m getting ready for a sprint this week so the past two weeks I would do 20-40min intervals above my sprint race watts (240-260). You can also do shorter intervals say 5min @ 300 watts or 1min @ 360 watts.
Most people on ST will ask what your weight is and what your FTP is. To figure out your FTP do a warm-up then ride as hard as you can for 30 minutes, whatever your average watts are for those 30 minutes is your FTP.
You can find more information on training with watts at trainingpeaks.com
You should do a power test. A CP20, take 30min to warmup and then go all out for 20min. That 20min avg power is your CP20 number, which you can then use to base interval training off of.
http://www.training4cyclists.com/
http://www.saris.com/t-CPTC.aspx?skinid=2
www.theendurancecoach.com/uzone/Cycling/Downloads/CP20.pdf
The reality is, if you aren’t going to train with power, this data is essentially useless to you. If you are, get a power meter, do an FTP test, and get to training with power. For a couple of years prior to training with power, whenever I did VO2 Max test they would always give me my power too (test were done on a computrainer). That info never did me any good until I bought a power meter. Now I will never go back.
