Ok all you Oakley fanatics (Tom D!), here’s a question.
Are the frames of each of the Radars specific to that kind of lens? Basically, could I put a pitch lens in a path frame?
Thanks!
Thanks!
As far as I know any lens for the Radar will fit just like the M-Frames
The exception is the new Radar XL frames and lenses. Because they are a taller lens at the nose bridge they will not fit in a normal Radar frame. Othewise, all radar frame shapes will work in regular Radar frames.
All correct. In fact, if you wanted to put an XL lens into a standard frame, you could do so by swapping out for the XL nosebridge (where to buy one? Don’t know - I bet Oakley Warranty Department could hook you up if necessary).
But yeah, Path, Pitch, and Range lenses all fit into standard Radar frames. I should know:
http://i35.photobucket.com/albums/d156/Triathlon-Lawyer/SLZ_6960_dev.jpg
You are missing a pair. ![]()
thats SICK!
what are the neon green frames? custom or limited?
I concur. Have them both and love them.
