Question about FSA RD-200 Wheels
I’m trying to service the rear hub of my RD-200 wheels. Basically all I want to do is remove the cassete body, clean everything and lube the pawls. I could remove the axle nut on the left side but i don’t know how to do it on the right (drive side).
If any RD-200 owner tried to do this before, I would appreciate any help.
Thanks.
bump!
http://www.fullspeedahead.com/downloads/copy_RD220S%20drawing.pdf
I presume you have the correct tools for the job, servicing hubs without cone wrenches is a disaster in the making.
There should be 2 nuts on each side of the hub, one tightens the other is like a lock nut. Only remove one side, then slide out your axle. If you are not careful when you re-assemble the hub your wheel will be out of dish and not centered on your bike. and the previous post was correct, you need cone wrenches.
