Quarq Sram Red PM and O,symmetric rings
Does anyone have any experience with fitting these rings onto the SRAM red quarq power meter without voiding warranty or without comprising the accuracy of the meter significantly? I know that generally 3rd party rings aren’t compatible with this meter because of the hidden bolt design, but I was curious to know if anyone has come up with ways to make these two products work with each other.
I am not sure on fitting them but from what I remember Q-Rings affect the accuracy of a crank based PM. Scroll down a bit and you’ll see the section
http://www.slowtwitch.com/Tech/Power_Meter_301_3696.html
Now is it statistically significant? Probably not from your one session to another for you but possibly comparing from a current PM you may have.
If it’s a new Quarq, the torque strain gauges are in the spider, and users are free to swap rings w/o factory re-cal.
On to the bigger issue, fitting them, that’s where you might be in trouble.
At best, you’re looking at chain pins out of phase b/c of the reoriented pattern of the new Red, at worst you’re looking at some mods.
There is a lengthy thread on WW about Red Quarqs, fitting Stronglight & Praxxis rings, etc.
