So, I guess I should have asked this questions before I purchased my Quarq, but now I am trying to figure out what am I going to need to make this work, or even if it will work at all…
Ingredient 1:
2014 Cervelo P2, which was fitted with Ultegra Di2 gruppo all around
Is it going to fit? Do I need a new BB to make it fit? I had a FSA Gossamer there from factory and I do not see a spare BB in the box that I got from my LBS.
Ah, you’re right. The new P2 are BBRight not BSA. You’ll need to remove the NDS spacer and bearing preload adjuster and get a wave washer to preload the bearings.
