Quarq And New P3
Hi mates
I want to know if GPX Quarq that i use on my Plasma Premium will work on New P3
Thanks
You will need an adapter for the BBrite Bottom bracket or a new bottom bracket but sure.
you can send back to quarq for 3-350$ and theyll reinstall that power meter on a bb30 which will fit directly and theyll send you back a gxp crankset without the PM installed.
I would recommend getting a GXP-to-BBright adapter. I wanted to use my existing BB30 crankset on my Cervelo NP2, but the spindle wasn’t long enough. I ended up getting a nice BBright crank on eBay. If I had a good GXP crank, I probably would have just gotten the adapter. BBright is BB30, but with a longer spindle. Most BB30 cranks won’t work with BBright. However, most SRAM/Shimano cranks will with an adapter.
-Pete
Hi mates
Thanks
Yes it will. Your best bet is an adaptor made by Rotor: http://www.cart32hostingred.com/cgi-bin/cart32.exe/ROTORCOMPONENTSLLC-store?catid=256998500&prodid=258530650&Theme=Basic%202
Click the drop down on the right and select the BBright to GXP adaptor of your choice.
Getting these into the frame takes a bit more effort that the expression “press-fit” suggests. I ended up using a lot of grease, two thick pieces of wood and a large G clamp. They tend to soak up pressure and then jump in a few millimetres at a time with a loud and alarming noise.
The other issue to be aware of is that space is a bit tight for the magnet. I used putty rather than the O-ring. The magnet can end up fouling on a small flange on the inside of the (compact) spider - I ended up filing the contact point away. All works well now.
-Pete
Tom A will hopefully chime in but I thought the only delta between BBright and BB30 is the number/width of spacers. Other than that, the spindle and ‘stance width’ should be identical. I just put my BB30 Quarq on a New P3 with BBright this spring…no problems. The only issue is the clearance of the Quarq magnate on the drive side. Super tight fit that I solved with a hot glue gun, but you may want to install the quarq firmware that allows you to go “no magnet” (I have not yet).
-Pete
You are correct the newer BB30 quarqs have a longer spindle and will work if you remove the non-driveside spacer and use a wave washer instead.
Still, I would just use an adapter with his existing GXP crank.
-Pete
Thank’s mates… that what i’ll do!!! gonna get an adapter! :wink:
The adapter will probably work just fine but the best thing to do would be to use the proper spindled cranks without adapters. The BB30 cranks for ELSA/RED are $435 and for RIKEN are $376. If you send the Quarq to us, we only charge for the cranks and return shipping. Labor, calibration, and a stock spider installed to your GXP cranks is free.
Cheers,
Rob Bee
Quarq Tech Service
