QR sizing
5’9ish on a 54cm Seduza
31 inseam.
Too big or most likely pretty close with the right fit?
31 inseam.
I think you’ll be fine. I’m 5’9 and rode a medium (54) Lucero - which is the same frame. Obviously, more goes into a fit that, but in general terms, you’ll be fine.
Thanks Mac. What stem did you have on there?
Spacers?
I am 5’8.5" and the medium fits just right.
31 inseam.
5’ 9", ride a 2010 size medium Seduza, seems to work great
33+ inseam, I could NEVER ride a small, i would be better off on a large
I think a 54 will work…but what year is this?
EDIT: I should add that the bike is wicked bad. As in, it F&%#*NG rocks. Scary fast- best bike I’ve owned. It’s such a good deal too- sure for 3x as much you’ll get better…but is that much more worth it? I didn’t think so at this point…
Upgraded Vision bars and Rival crankset w 170s.
Oh, and the Adamo! :slight_smile:
Same as you 5’9" 31 inseam, rode a medium Lucero lite that fit like a glove :0(
that’ll work (probably), you most likely won’t have much seat post showing…
Mine has upgraded carbon easton and PD bars, carbon stem, Cane Creek carbon brake levers, TRP brakes, FSA K-Force Light crank, dura ace cassette
hella fast
(oh and H3 and Jet 60 help too)
3.5 in of seatpost right now.
I don’t ride steep, but a good 2in of drop to the pads
I think I rode with a 90. Probably 5 cm of spacers.
Thanks Mac - sorry for the ‘20 questions,’ but how about seat setback?
I realize some of it is highly personal, just feeling like I can’t get the fit right…
On the Adamo, I have it pretty far forward on the rails, 100mm stem, and 3-4cm of spacers.
The pads are also on the 2nd setting up (25mm)…
I agree. You’ll be fine. QR’s have quite a bit of adjustability range
I was on an older model that had much more limited adjustability than the current model. I used a Fizik Arione Tri 2 saddle at the time.
The bike should come stock with a 90 mm stem and the seat post should give you about 5 cm of adjustability.
Does anyone know of a quality S bend setup with the Vision base bar?
I have the Vision ski on there now…and want to keep the base, but don’t want the Vision R or straight extensions.
Any suggestions?
