Has anyone tried it?
I guessing it pretty straight forward but I’m struggling to find what I would need to buy
http://www.rotorbikeusa.com/...patibility-chart.pdf
110mm BCD you’ll need the OCP3 version of the rings. Find the road compact rings, select the size and choose the OCP3 version but beware your are limited to that one position.
130mm BCD any will work but in this case don’t buy the OCP3 as they limit the position possibilities.
You can make it work, but it will look like hell! ![]()
I’m a life-long Shimano-man, but if I was going with Q-Rings and I was running a DA crank, I would swap it out for a Rotor crank or a “non molded” and non-proprietary FSA crank. It will look a lot better - FWIW
I know what you mean
I’ve just been looking at a YouTube video and it does end up looking like a bit of a bodge
Do I save some money and ruin the look of my bike
Naaaaa ![]()
