Just trying to install my 54/42 Q-rings and run into this. Unfortunately, I think I know the end conclusion, but any ideas on how to get around this? The FD is all the way up(braze-on) and I don’t think dremmeling the notch larger will give me enough.
Again, I’m assuming the choice will be 1. Get a 53, or 2. Get a 53.
Dammit that pisses me off.
Not much you can do with a braze on. My Q-rings just fit on my Cervelo SLC with the front der pushed all the way up. Perhaps a different front derailler as well? Campy is nice and all, but maybe an Ultegra one might work? Blasphemy I know …
Nope, no other FD has been able to clear it tonight. I’ve tried Record, Chorus, another Centaur and an Ultegra.
I pulled a 53 Q off another bike and it’s having a problem with clearance on it too. I think the dremel will work for the 53 though. Oh well, we’ll see. Guess the 54/42 is going to the classifieds.
Hello,
You can likely fix it two ways. The first is to drill and tap a second hole in the FD mount. The second is to grind the FD cage a bit, possibly in conjunction with dremelling the braze on.
