Yes, another Q-ring question, but I didn’t see any other posts that was similar to this so I here’s a new one:
Here’s my set up:
- 54 TT Q-ring and a innner 40 Q-ring.
- Big set on 5, Small on 4.
- I am WAY forward on my bike, but that’s just the way I am (even on my road bike)
- Polar Power Sensor as my power meter.
Here’s what’s happening in general.
There is a huge discrepancy in power when switching from big ring to little ring.
On a good long climb I can produce anywhere from between 220 - 350 watts in the little ring.
On the flats, If I’m on the big ring, I have to put in a LOT of effort barely get over 200 Watts.
This is the weirdest part. When I’m on say a gradual incline, where I’m between the big ring and little ring, and going at the same cadence (I tend to ride in the 90s) if I switch from the big ring to the little ring, I go from ~180 Watts to ~220 Watts instantly. No real change in effort and not real change in speed, but definitely a change in power output.
54 x 19 and 40 x 14 is approximately equal, so I tested this on what is basically a flat road. I can literally see my power change as I switch back and forth from these two positions.
I know what I really have to do to test this phenomenon, but I just don’t have time given that I’m training for an upcoming IM and holding another job. So I was wondering if anyone else has had this “issue”.
Some things to consider:
The aspect ratio of the 54 and 40T rings are different. There is a wider range for the 54T (57 - 51.8) than the 40T (38.4 - 42.2). Since the 40T small ring is “rounder” does this mean that maybe I should be on a chain ring that is less of an oval? I’m also a “spinner” so, might a rounder ring be better for these types of riders?
I’m also questioning the power meter I use. At what rate and at what point in the pedal stroke is the power sensor grabbing data? could it be that the chain tension is artificially low at the point that the power is be sensed, or should i be producing constant power through the pedal stroke such that it doesn’t matter when the power meter is grabbing data?
Anyway, as you can see, I’m profoundly confused by my observations, and would like to see if anyone else is experience what I am. I’m starting to think that my reliance to power is too great and that I should go back to basics and just ride by speed ![]()
Thanks in advance fellow ST’ers. I look forward to your responses.
