Q for the XC ski folks
I went out today for the first time in probably 15 years. Classic. I took a lesson as I figured it couldn’t hurt, and we went over the basics. I have to say, controlling a snowplow without the solid connexion to the ski like you get with a DH boot/binding was something else! I ended up just bailing a few times because I couldn’t scrub enough speed - I’m gonna have to work on that. ;-p
I put my walking orthotics in my boots figuring that it was probably a good idea, and my feet hurt after a few minutes - but I guess my feet got used to it because after 1/2 an hour or so the pain (and need to stop to rest my feet) went away. After a few hours in the trails however, my elbows started to get sore. It’s similar to the elbow pain I got from swimming when I jumped into a 4k open water race on zero training. Anyway, I figure I must be doing something weird with my poles. Without seeing me ski, do you have any idea as to what I may be doing so as to bug/strain my elbows?
Thanks,
Same thing here. I am guessing it is from not having that great of technique on the lower half (legs) and trying to pole to hard.
Depending on your technique, there can be substantially more eccentric muscle action of the elbow extensors in XC skiing. Just like the first time you lift weights, or run after a lay off, this eccentric action will often result in soreness even in trained muscles.
I would bet that you are coming down too hard on your poles. I experience similar pain on roller skis on pavement because there is no give upon impact. While classic skiing at slow speeds (I assume this because of the 15 years thing), you dont have enough forward momentum to ease poling down into poling behind you (pushing you). Do not stab the ground, place your baskets on the snow and - only when they are behind you - give a push. This will work your triceps instead of trying to pull your elbow apart. Also, make sure your poles aren’t too short.
And don’t snow plow… pick up your skis and step around corners, pushing off your outside foot to maintain/gain speed.
Chances are you are not “crunching” enough when double poling (letting your upper body weight do the work), and on diaganol stride keeping the arms too straight or stiff. Also, be sure you are loose and light with the hands when following through in the poling motion. No death grip. Rock just a bit forward with your hips as your lead leg travels down the track, this will get you committing fully to the gliding leg, and it takes pressure off the elbows and shoulders as you are then rocking back slightly to the other leg and following through with the poling motion.
Mostly, it’s staying relaxed and letting the skis glide. Poling in XC should be less about forward propulsion, and more about rythmn and timing of your kick. Only when you are in a dead ass sprint double poling should you really reef on the poles. Not something too worry about unless you are in a race.
Let it snow.
OK, just for fun I thought I’d try and replicate your elbow issue this afternoon on my local trails. What I found is that I get elbow pain by planting too early, and then pushing too hard. Kind of like heel striking in running. You shouldn’t need to reach out with the pole, but rather keep it closer to the body, planting behind your foot after you start your stride. When striding you should be initiating from the feet up, staying on your toes almost, finishing with the pole plant and glide. If you get the chance to get a good side look at someone who seems to know what they’re doing, look at where they plant their poles, and how close the hand is to the body to get the idea.
Khai,
without seeing you…I will assume you are doing a few things.
  1. hips are low and back, aka you are “squatting”
  2. reaching and planting the pole with a near straight arm
  3. compensating with arm strength/poling do to a lack of weight transfer and never “setting” the wax (see #1)
Check these pics: http://www.fasterskier.com/racing3865.html
Note the second shot of Chambo, note bend to elbow and where pole is relative to foot.
I am glad to see you are skiing classic, it is the best way to improve your skating!
For us New Englanders…4 x 4min uphill V2 on rollerskis yesterday…great.:frowning:
Man, do I ever love SlowTwitch! Collectively, you guys know EVERYTHING. :slight_smile:
Thanks guys - I’m pretty sure I was poling way too hard. I may have been “squatting” as well, although I don’t think my arms were too straight - it’s hard to say without a profile picture. My weight transfer definitely needs work, as this was my first outing in an age and a half. That should improve with practice, along with my timing.
The reason I was snowplowing is because here in BC, (or at least at Cypress Mountain) the XC trails are quite hilly - having green/blue/black designations. I used to be a pretty decent DH skiier, but the technique is pretty different. All of my XC experience was in Ontario, where it is pretty flat - thus I never had any descending issues. Given that my skills aren’t quite up to the point where I can just “tuck and bomb”, what is the best descending technique? I have to say, yesterday marked the first time in my life where I was actually better at going *uphill *than down!
hey next time you go, give me a call, I’ll come see what you’re doing wrong :wink:
AP
khai, do a search back a few weeks, there was a thread on this.
basically:
neutral, athletic position, dont lean back or too far forward
hands in front (imagine a steering wheel in your hands)
soft knees
small “steps” through the corners, or rail the tracks
ski with joy.
Kurt
