PT SL Failure to Zero
Has anybody had an issue with the PT SL failing to zero in cold weather (cold being 35 - 42 F)?
I try to zero and it will only drop down to about 22 - 32…After I get back into my 68 F house, it zero’s just fine. The batteries are new in both the Hub and the Computer.
It was very strange…It’s done this a few times on colder days. Today at one point later in the ride I was able to zero the meter, than 10 mintutes later it went out agian…
Any ideas?
Did you leave the bike in the outdoor air before starting your ride? It is fairly common to see people report inconsistencies in power readings when they take the bike through a big temperature change and start right away, i.e. unheated garage into house for trainer ride or house to cool/cold outside. Try leaving it outside for 10 minutes or so before you start.
It went from my heated home to outdoors…The bike sleeps inside, the kids (different story)…
You’d think over a three hour ride you would be able to calibrate…Is this not the case?
