PT Headunit - Quarq Powermeter
Anyone got this working? Have googled and searched, but not finding much luck.
Optimally I would have my Garmin 310xt by now, but I can’t get any answer from Garmin other than “Be patient”.
So, what I currently have is a Powertap 2.4 headunit. Updated to the latest firmware, so that it is compatible with a PT SL+ hub.
Is it possible to get the PT cpu and Quarq to sync up? It reads the HR strap ( I have a Garmin 305 ) fine. But no amount of spinning the crank during the ‘find’ or ‘learn’ mode had any luck. The shop that installed the Quarq tested it with a 705, so the crank works.
So, anyone have any suggestions on getting the two to work?
-Chris
-Chris
According to Saris…No comprende…although the PT+ hub transmits an ANT+ signal, it also transmits the original Saris proprietary ANT signal. The PT head unit ONLY receives the ANT signal, not the ANT+ signal.
It’s not gonna happen…
Darn, okay. Well, that’s what wasn’t quite clear, that the upgrade to the headunit after upgrading the hub to ANT+ did not also update the CPU to be able to use ANT+.
At least I know to stop beating my head against the wall.
Thanks!
