I have my PowerTap Pro+ up and running but am having a hell of a time downloading the data from the little yellow Cervo head unit to my laptop computers. I’ve tried transferring it to my Mac (PowerPC running 10.5.8) and haven’t had any luck (I’ve tried both Golden Cheetah and PowerAgent). I’ve also tried transferring the data to my PC and it worked once with Golden Cheetah, but since then nothing (I’ve also tried PowerAgent). On both Mac and PC it doesn’t “see” my device, or I get some sort of error prompt. I’ve also tried installing the FTDI driver on both computers (as per the Golden Cheetah website), but that didn’t help either.
Anyone else had these issues? If so, is there any workaround?
I had a similar experience with Power Agent on Windows. I haven’t tried Golden Cheeta. I spoke to Cyclops/Saris customer service and was told to return my download cradle. They replaced it with another one and I was good after that.
Check you’re pointing to the correct USB port.
For some reason the same USB on my laptop has changed from Com1 to Com5.
Make sure in the download port dropdown, that you are using the COMn(usb serial port).
