PSA: Sig 227 FDE
The 9mm version of this (p226) is issued to Navy SEALS.
TACOPS version is the issued pistol.
It is basically a high capacity version of the 220. One of the most tested gun models out their and known to be the most accurate out of the box. It is new. While I’m a big fan of the 220,** I don’t know why this hasn’t taken off**. The price point is good. I think if given the choice between 8 rounds in a 220 vs 10 in the 227, people go with tried and true. The dimensions are immaterially different, and 2 rounds of .45 doesn’t change the weight significantly. This gun has made me consider buying a domestic made sig.
Double stack .45 is not as reliable as single stack.
This is really interesting to read as I have never heard of this ‘reliability’ issue on any Sig double stacks. Are you saying it’s b/c of the caliber? I have been shooting a Sig P226 in 9mm for over 25 years and I have never once had a problem with my 15 round high cap double stacks. Tens of thousands of rounds or reloads. What exactly is the problem with double .45 doubles?
Weight of the rounds (9mm 115gr vs .45 230gr or over 50% heavier) and factory springs used to push that weight up. Yes you can get 185gr .45 (38% heavier) but if I am using one of my .45s I want the stopping power of 230gr and reliability of single stack mags. I have small hands as well but that is totally separate issue on using double stacks.
As I was responded to the bolded quote of why this hasn’t taken off, I said double stack .45 (STI, Para, etc) are not as reliable as a single stack .45. This is part of my guess on “why this hasn’t taken off”. I believe this is Sig’s first double stack .45 as well (not positive as I am not a Sig man first). First run productions have been known to have issues as well. 25 years use vs 2 years of use. I’ll take the 25 years any day.
I also have a Sig P226 TacOps with over 250k rounds through it. I wouldn’t trade it for a new 227.
Ah ok. My 1911 is a single stack so never had an opportunity to experience any issues of the like. So you are talking about stovepipes? Failure to feed/load is something I’ve not had to experience, but the times I see people bitching about it at the range almost always end up with. ‘You mean I have to replace my mag springs? They wear out?’. Oddly I had the toughest time finding 15 round mag springs for my hi cap mags. Sig stopped making them in an effort to create a new revenue center for their 20 round I guess b/c there are only a kabillion 15 round mags in circulation(pink font), but I don’t like having extra mag sticking out the bottom so have kept on with the 15’s. Took me forever, but I found a box of them and bought 'em all.
I have never heard this before. I have a couple thousand rounds through by Glock 21 w/o a single issue. I have never seen or heard any issues with the Glock 21 double stack mag. Is this a Sig issue or double stack .45 in general?
Also, the Glock 21 is surprisingly thin for a double stack .45. It isn’t 1911 thickness and is certainly more than the Glock 17, but, it is quite comfortable and can be shot by my very dainty daughter.
Once again the op stated he did not know why the p227 has not taken off. It had retailed for $1085 w/tritium and is now $600+? So my guess to that is STI & PARA double stacks had issues with feeding on double stack .45. Both reputable companies. Consumers know this and probably shied away. Keep your ramps polished, both double and single, and change out springs regularly is my advice if you want to run a double stack.
G21 had some extraction issues (curved extractor vs straight). That one is all over google. Obviously type/grade of ammo used makes a huge difference on reliability as well. Inspect your spent shell casings regularly with any Glock is my advice.
In the end if you are confident in the weapon you have…well that is half the battle when going into that 360 degree two-way range.
Yes double stack .45 has always had a niche following. Reliability in older models were sub par. But you are also referring to para and sti which were not combat pistols but more along the lines if match pistols that were good with ball, not so good with hp or other custom rounds. But this was largely remedied by glock. I have thousands through mine without a fail.
250k+ rounds?? That’s a LOT of shooting. Military or LE? What were the consistent wear parts? In 40 or 9mm?
I believe all those issues were Gen3 and were solved in the Gen4. I’ll stand corrected if I am wrong, but, I think I have that correct.
As I said in another post, I am not a Glock guy. I have a couple Glocks b/c they are utilitarian. I prefer Springfield, specifically the XD(m) series.
No doubt about that. That is why I stuck with single stack .45s for so long. But newer designs have proven quite reliable. It was a couple reputable shooters hosnsaidbthe glock doesn’t have tha problem. And mine hasn’t.
But then again one of them uses a g17 or 1911 and the other uses a g19. :wink:
Former MIL turned contractor turned retired.
What doesn’t wear out after 250k rounds? Recoil springs ~30k rounds, barrel at ~100k, slide catch lever spring ~50k, slide catch ~50k, firing pin ~50k, firing pin spring ~50k, sear spring ~50k, sear ~50k, extractor ~50k. Always replacing magazine springs as well.
This was just my schedule with P226 9mm off the top of my head. Some parts probably could have lasted longer but why take it to the point of failure? It could be one time I don’t need a failure to happen.
7500 rounds a month was pretty normal for pistol shooting. During some periods we would get up around 15k a month on pistol. We went through A LOT of weapons parts/weapons in my unit. Once I got out and started contracting I would average ~200 rounds a day of pistol.
I will always go with single stack .45. I am a big believer in having confidence in your weapon and had some issues with the PARA 14.45 so done with them. I am sure as time goes on manufacturers will get better with them.
I also have the G17, G19 and G34. G19 has had some stove pipes first 1000 rounds but I fixed that BS. Probably 10k through the 17 &19 and a lot more through the 34 (pretty much everything is aftermarket on this one though, my comp pistol)
Kind of like my great grandfather’s hammer. I still have it - only changed the handle 3 times and head twice. :wink:
