Proper lactate protocol?
Do any of the experts out there know the proper way to administer a lactate test? Thanks
Running, cycling or other?
Who are you giving it to?
Lots of different factors.
Typically it goes something like this…
  1. Health history / consent etc
  2. familiarization with protocol / bike set up
  3. Warm up / determine first stage
  4. Begin test
    a. 3 min into stage, wipe finger with alcohol, gauze, prick, wipe, sample,
    bandaid. Check HR and RPE. Record everything.
    b. Move to next stage at 4 minutes
    c. repeat until your cut off point. Different people use different criteria.
  5. Finish test, cool down.
Bike and run myself or friends, not for business. Health is great
For something like a run, its easy enough to do on a treadmill. I would try to calibrate the TM to help with repeatability.
For cycling, you’d need something with repeatable power outputs, like a computrainer. This way you can accurately control and increment the workload. This is not only important for this test, but also all future tests for comparison’s sake.
Find someone who knows how to do it, pay for an initial test to see what the deal is and learn from there. Probably the best way.
Worse comes to worse you can do a conconi test, which may or may not give you accurate results.
