One thing I did not like about the HC is the rear mount for the computer.
Agreed. That would be annoying. I didn’t use the mount that came with my HC, and instead built a bridge between my aero bars and mounted my Garmin in front of the bottle. Much better and technically in front of the bottle and not up on top of it. Like this if you can see the pic:
Was just trying to decide between this and SpeedFil BTA option. This bottle looks more secure, but the Garmin issue is killing me. Direct mount to bottle on SpeedFil. So is the consensus that it’s really not safe having the Garmin out front on this bottle? Is there any additional mounting pieces required? The velcro idea isn’t awful except I move my Garmin between my road bike and tri bike. A tad bit frustrating that somehow Profile missed on this aspect!
To my eye, the up front garminount with a unit attached will incur a significant drag penalty. As much as people complained about the behond-the-bottle mount of the HC, it was very aero.
I’m also not a fan of the way that the gel storage box is designed. A storage space like this is great in principle but Profile Design seem to have made it for the gels to stand upright? That makes no sense.to me from a drag perspective
The Zipp Vuka BTA mount has the best computer mount on the market
So these brackets accept standard water bottle cages also? Bc I have a ton. So I could buy the bracket, use a standard cage and just need to find a speedfil or some type of easy refill bottle?
Yes, you put whatever bottle cage you want on it. For the XLAB torpedo, you would use the Torpedo cage. For the profile design, you can use the cage that comes with the HC bottle.
From the website.
Combine the TriSports BTA Modification Bracket with a Zipp Vuka Alumina BTA Mount with QuickView and you have the BTA Mount 1.1 from TriSports.com. The BTA Mod Bracket was developed in-house by our professional mechanics and bike fitters.** It’s designed to modify the Zipp Vuka Alumina BTA Mount to work with larger Torpedo-type hydration systems. We developed this bracket in order to merge the best assets from Zipp (their bracket) and XLAB, Profile and Speedfil (their bottles).** This BTA (Between The Arms) bracket comes with mounting hardware and easily retrofits the Zipp Vuka Alumina BTA Mount with the included screws. Once the Zipp BTA Mount is attached to our modification bracket, you can use it with the XLAB Torpedo Bottle, Profile Design Aero HC or the Speedfil A2. The system mounts securely to your aerobars and keeps the Garmin computer stable, making it much easier to read. And it keeps the bottle stable on rough roads as well. This BTA system is compatible with all Garmin Edge 1/4 turn twist-lock computers. Designed and made in the USA, the BTA Bracket is machined from lightweight aluminum. The TriSports Torpedo BTA Mount 100 takes a good idea, and makes it great!
The adaptor is $20 by itself if you already have the Zipp BTA Mount. The BTA 1.1 mount is the Zipp cage with the adaptor. Then you pick your choice of BTA bottle
First off I’m happy to see the response to the system has been positive.
I haven’t chimed in yet because I am talking with the poster with the computer mount issues to find out what’s going on.
The mount for the computer was designed to be wide enough for a Garmin mount and the diameter is 2mm larger than our standard computer mounts. With that said this is the only complaint that we’ve seen regarding the computer mount and we havent had issues with any of our athletes or product testers in the past 6 months of testing.
I’ll keep you posted with further information as I receive it.
Just a slight clarfiication…for the Torpedo Refill bottle any XLAB cage will work, not need to buy the Torpedo cage specifically. There may be other cages on the market that work as well, but we have tested all of our cages and found the Gorilla, Chimp, Torpedo and Vee cages are 100% compatible.
Cannot for the life of me figure out how to mount the computer on this system. Not an ounce of instructions included with the system for how to do it. Anyone any clues?
Computer mount for Garmin 510 is easy using standard hadlebar mount with the out front location. I added a small piece of velcro under the mount for stability, but not sure that was needed. I like the design of the mount, although I did get quite a bit of splash. To be fair, I filled it pretty full (35 ounce model) and had some pretty bad roads at times with construction, etc. Have not tried it on smooth roads only yet. Did not use the litte storage space in the back, but might use it to hold pieces of honey stingers in my half coming soon.
