I just started putting my TT bike together and the Di2 FD won’t go low enough for my compact cranks. Is there any way to get this to work? At this point the only way I see getting the bike built with is to get rid of Di2 and get a cabled FD that will get me low enough.
Is it bottoming out on the top of the braze on hanger or is the bolt hitting the bottom of the hanger? I don’t think that a mechanical Shimano FD will even get you there. Older SRAM FDs (non-Yaw) have two mounting holes which will allow it to go lower.
The bolt is hitting the bottom of the hanger. I don’t see how a Dremel will fix that unfortunately.
I will look into a SRAM or possibly an old 10s Campagnolo compact FD. Hopefully one of those will get me low enough. I need to get the compact to work as I don’t want to have to buy a SRM specifically for this build.
Looks to me like there is enough “meat” to lengthen the slot in the FD hanger to at least get you low enough for it to work. Di2 is pretty good at accommodating non optimal FD positioning.
It was a running change, somewhere around 2008 or so, as mentioned above. If you’re buying a used one, check to be sure. If it has a 50, it fits compact. If it has a 53, look to see if there’s about 6 mm of downward adjustment in the slot. (Each tooth needs about 2 mm adjustment.)
Let me know if you want it shipped to the UK as my work has an office this. They will then ship it to me and I can give it to your sister or I can send it to you.
Keep in mind that this riser block, even if inverted will push the derailluer to the rear of the bike. As it moves rearward it gets farther from the chainrings.
I used a spacer to move a derailluer rearward just to get clearance for a 53t rotor ring once when my hanger was too low.
