Selling off some items I no longer need as I move into the new racing season here in North America.
Please shoot me a message if interested or need any further information on any of the below items.
Drag2Zero .66 Aero Bars with Risers - $1200
Bars have been used for 1 outside ride and 3 indoor trainer rides. Bought to try to mess around with my fit and decided to keep my existing set up. My loss, your win. 15 and 20 degree risers, BTA, Computer Mount, Both Standard and Long Grippers for Shimano Shifters, Extra Set of Arm Pads etc. Pole clamps and 1 spacer on each pole have slight wear as I did Dremel the spacer to put the BTA in the higher position. Please find the detailed list below of all the bits included:
Gen2 Angled Shim Sets - 20
.66 Pole Computer Bracket - 20 Degrees
DUAL BTA System Standard Base Clamp - 20
Gen2 Riser Bolt Kit - 25-50mm
Gen2 Grip for Shimano SW-R9160 Shifters
Grip Length:
Long Gen2 Grip for Shimano SW-R9160 Shifters
DRAG2ZERO.66
.66 Pole and Armrests:
.66 Pole and Armrests with Standard Grip
POL-66
.66 Armrest - 66 Standard Armrest
.66 Finishing Kit
.66 Pole Blanking Panels
.66 Armrests Bolts
Bar End Plug
Arm Rest Foam - Foam for .66 arm rests
Pole foam - .44/.55/.66 Pole foam
Standard Grip Selection:
Standard Gen2 Grip for Shimano SW-R9160 Shifters
Mounting Kit Selection:
Universal Baseplate Mount Set
M5 Hex Weld Nuts
4
M6 Chamfered Square Nuts
4
Angle Shim Selection:
Gen2 Angled Shim Sets - 15
Gen2 Angled Shims Bolt Kit
Pole Clamp Set:
Gen2 Pole Clamps
5mm Riser Sets:
Gen2 5mm Riser
10mm Riser Sets:
Gen2 10mm Riser
20mm Riser Set:
Gen2 20mm Riser
Riser Bolt Kits:
Gen2 Riser Bolt Kit - 5-25mm
Computer Mount Type:
Tower Computer Mount Kit for .66
Tower Computer Mount Add-On
Computer No-Turn Inserts V2 - Garmin
.66 Pole Computer Bracket - 15 Degrees
Computer Spacer Kit
DUAL BTA System:
Standard Width DUAL BTA System
DUAL BTA Add-On
DUAL BTA System Standard Base Clamp - 15
Dual BTA Height Adjustment
DUAL BTA - Gen2 Mounting Plates
Factory Recertified Garmin 965 - $275
Replacement direct from Garmin for my previous watch. Still has the plastic on the face.
New in Box V1 Core Body Temperature Monitor - $100
Bought 2 units and have only ever used one. Brand new in the box, never used.
