I was trying to find the specs for the 2008 powertap SL 2.4 hub but I have been having a difficult time. Does anyone happen to have the specs handy? What I am most interested in is what size axle does it use? Is it a 12mm aluminum (like the '09 Pro+) or 15mm aluminum (like the '09 SL+) axle? (I care because I am a clydesdale).
Either way (sorry, I don’t have the answer), it seems like you could have a titanium axle turned for relatively cheap and not gain more than a handful of grams, while ensuring a significant increase in strength.
I believe you can also pay to have the 2008 versions upgraded to the 15mm axle, and if you needed/wanted further strength, you could get a 15mm titanium axle made.
Hey Jordan, quick question.
I have my bottle mounted up front, which I believe you still have set up too.
Where do you put your PT comp? I just ordered one. I assume it’s on the stem?
Not that I need to stare at it, but can you see it ok ?
