has anybody taken delivery of the new wireless PowerTap? If so, what are the early impressions?
I’ve had one for just under a week. Have used it indoors twice. I have no prior experience with power meters, so I can’t provide much of a comparison.
The first time I used it, I was concerned because it kept cutting out and having to search for the signal from the hub. It did this about 20 times over the course of an hour and each time represented about a 30 second drop-out in the data. Aggravating.
But I had a conventional computer mounted to the bike that I was using to test the accuracy of the PT speed reporting. Apparently that caused interference 'cuz I removed it before the second session and had no further drop-out problems.
Everything seems fine except that the cadence reporting doesn’t seem right at tall. I have a very steady, smooth spin. This thing measures cadence in the hub somehow and it shows my cadence going all over the place.
For the convenience of being able to move this between a couple of different bikes, I think it’s going to be a nice deal. I just need to watch that cadence thing and see if that continues to be a problem as I finally get the thing out on the open road.
To calculate your cadence, the PowerTap relies on measuring the time from one peak in torque to the next. This works reasonably well if you’re stomping hard enough (e.g., high power, low cadence), but not-so-well when/if you’re pedal action is “light” (e.g., low power, high cadence). I expect that it will generally work better outdoors than indoors, but if you find that even outdoors the cadence measurement is too erratic for your taste you can always get their wiring harness that relies on a magnet on the crank.
Exactly. I was doing a roller session and was especially surprised when I removed the flywheel resistance for some high-cadence spin stuff. Thanks for the explanation.
Now … to the OP. I’ve encountered what MAY be a serious problem with the unit today. I’ll elaborate further when I have a chance to speak with the folks at CycleOps. There may be some user error issue, like something I screwed up during setup. I want to check out all the possibilities before I post more details.
OK, to elaborate on the issues I’m having with my new PT SL 2.4 (and get some input from Mr. C, perhaps):
We’ve had a cold and wet spell here since my PTSL2.4 arrived and I’ve been stuck indoors mostly. My unit is on a 650 wheel I use on my TT bike. I don’t have one for my road bike.
I’ve done two indoor sessions. Both have been on rollers with a fan unit that provides resistance (and some cooling). I also have two fans pointed at me for cooling. These “indoor” sessions are actually in an outbuilding and during both sessions I was only able to get the temp up to about 58 degrees using a heater before the trainer session. Regardless, I worked hard enough to sweat bullets.
This past year I did a 10 mile TT at 29.7 mph, won my age group in the state championship 40k, did a 1/2 IM bike at 24.6 mph, etc. Imagine my surprise and dismay when I was dying trying to sustain 230 watts for more than 3 minutes on the rollers. I did a couple of 5 minute efforts where I pegged my speed at 26.0 mph and the watts hovered just over 200. I was very ready to be done with them. And I concluded that I must have completely botched my winter program. I was very discouraged.
Today I went out with a buddy of mine on a 3 hour training ride on road bikes. He has a power meter pro that he’s used for a couple of years. So I was asking him to tell me what kind of watts we were doing at various times. I outweigh him by about 15 pounds, so presumably, if I was riding alongside him, I was putting out at least as many watts as him and probably more. Well, on the road we were conversing at 200 watts. We did several hills where I know we were well into the 300 range. I’ve asked him to send me the file so I can report the numbers more accurately to you, but I don’t have it yet. To make a long story short, we never did an effort in our three hour ride today that felt anything close to the 5 minutes x 200 watt efforts of those roller sessions. And yet our wattage readings were 60 … 80 … 100+ watts above that at times.
So tonight I discovered the wattage group on Google and read about indoor power drop, but what I’m seeing here seems to be on a much larger scale. I’m wondering if the revolving drums on the roller are having some kind of servo interference kind of effect on the wireless unit. Or maybe it’s the combination of interference from the rollers, fans, TV, lights. Maybe if I just use the thing in a dark, still room I’ll get some accuracy.
I still haven’t had the wheel on an outdoor ride. I’ll try to get outside with the TT bike on Friday. We have a major road project going on with convoys of huge stone-hauling trucks going up and down our normally-quiet country roads right now. I hope they won’t be running on Friday.
Any insights on all this? I’m sure gonna be bummed if this expensive new training tool is useless for indoor training sessions.
OK, let’s start with the easy solution first: zero the torque.
Sometimes while riding a trainer (a rare instance for me), the torque somehow has some ‘negative drift’ or something. I’m not sure if the procedure is the same for the 2.4 as the regular one, but regardless, it’ll be in the owner’s manual.
Secondly (and you should probably do this anyway), check the calibation. You can find the procedure on trainwithpower.net. I’m having trouble posting the link, so here are the snipped instructions. Thanks to Charles Howe!
As an aside, I just checked all of the PT’s around my house (5, 4 SL’s and one Standard with about 40K miles on it–and no, they’re not all mine!).
They were between .04 and .09 low. .05% variance–pretty impressive.
Hope this helps.
‘Technically, the PowerTap cannot be user-calibrated, but its accuracy can be checked using a simple test that is similar to the SRM calibration check. First, check that the transmission icon is on, and if not, give the rear wheel a spin. Then, enter the torque mode by holding the “Select” button down for 2 seconds or longer (the “WATTS” designation will disappear from the top line.) Apply the rear brake sufficiently to lock up the rear wheel. Now, measure torque as follows: with the cranks exactly horizontal (right crank at 3 o’clock), hang a known weight of at least 50 lbs from the right crank, or simply stand on it – hence the name ‘stomp test’! Measured torque = (weight in lbs) × (crank length in mm) × (1 in/25.4 mm) × (cog teeth/chainring teeth). For a 159 lb rider standing on a 175 mm crank, with the chain on the 39 tooth ring and the 23 tooth cog, 159 lbs × 175 mm × 1 in/25.4 mm × 23/39 = 646 in-lbs. Compare this to the displayed value by calculating % error as (measured torque - displayed torque)/measured torque.’
Bob-
Have you tried validating calibration of your PT? Instructions should be easy to find on wattage list. Basically, you need is a calculator, and a heavy item of known weight, and you should be good to go (barbells are dangerous, they’re w/in a range but not always accurate).
I remember somebody posting on wattage that riding the TT bike indoors just kills him. For whatever reason, he can’t do it (it may have been rmur but I’m not sure).
I think the outside ride will tell you more what’s going on.
I have pretty significant drop inside compared to outside as well, especially right after starting up trainer rides. My first ever entry into cyclingpeaks reads ‘I suck. Low cadence’. It was from a trainer ride.
I’d say give it a week’s worth of indoor rides or so to get used to it. I bet you see your wattage coming up, and your outside wattage may be a bit lower than you suspect. But the worst thing is having a power meter you can’t trust, so I’d start with figuring out if it works (so at least you know what your outside numbers are).
What did the Saris guys say?
Josef
Oops…one more thing: If you ‘zero the torque’ while the rollers are providing some forward momentem to the wheel, you’ll most likely get a false torque reading, making matters worse. That has at least been my experience. It’s best to do it while coasting on the road (though I’ve done it while static in the trainer and it’s worked fine).
Thanks for the replies.
I’ve zero’d the torque several times while everything was static. I’ll try the calibration test. Thanks for digging that up for me.
As for problems riding the TT bike indoors … I do it all the time. It does seem easier to ride it outdoors, but I’m quite used to riding it indoors.
I’ll be talking to Saris today. I’ll let you know what they say.
Thanks again,
Please be advised that I contacted Saris and got a very polite and responsive customer service rep on the phone who helped me solve the problem. I thought I was zeroing out the torque properly, but I wasn’t. I read a post in another forum where someone said you could zero the head unit on the wireless model without having the wheel spinning … and I believed it. Even when I started to doubt if that was correct, I didn’t think it could make the kind of difference I was seeing between what I believed the numbers should be and what I was actually getting.
But it did. When I put the bike in a workstand and got the rear wheel flying, then zeroed the torque, all was golden. I’d done a couple of tests on my rollers with a resistance fan attached where I was holding 26 mph for five minutes. From a perceived exertion standpoint, it felt very much like the level of effort I’d put into a short time trial. But before it was only showing that I was generating 200 watts. After correctly zeroing things out, that same 26 mph test produced 300 watts. That’s better. I’m not as much a wimp as I thought. I’m just too dumb to follow instructions.
