Powertap question (13)
I have a wireless powertap that I purchased in 2008. It is laced to an OP 28 spoke rim. It works great. Just yesterday, I ordered a new wheel from HED to be built around a 2009 powertap pro+ hub. I assumed the 2008 wireless 2.4 CPU will work with the new hub. Now I am concerned. Am I right that the wireless 2.4 CPU will work with a 2009 powertap pro+ hub, or do I need a 2009 CPU for the 2009 powertap pro+ hub? Saris is closed for the weekend so I can’t call them until Monday.
should work, you may need to go through a few steps for the CPU to learn the new hub. This info is on Saris website.
you need to set up the CPU to receive the new power tap Hub ID. pretty easy to do.
You’ll likely need to update the firmware on the 2.4 head unit to v7.53 or whatever is the latest so that it can read the ANT+ signal.
You may need to update the firmware on the Cervo (the computer). But any 2.4 part will work with any other 2.4 part, assuming that you have the latest firmware on each. (That’s a bit of an untruth, in that a 2.4 Cervo can read both ANT+ and non-ANT+ signals.)
2008 wireless computer will work fine. as stated- install latest firmware on PT computer to work with ant+ wheel- found at saris.com for free. latest firmware is backwards compatible- so it will work with your old wireless wheel, too. When you go to ‘learn’ the new wheel- it will learn the new ant+ wheel relatively quickly. it will take several minutes of the old wheel spinning to relearn that wheel. when you zero the hub- the wheel should spin for your old 2.4 wheel. when you zero the hub for the new ant+ wheel- the wheel should completely still (after at least waking up the wheel). i have too many PT wheels… :slight_smile: HED builds a really nice PT wheel.
Very helpful. Thank you.
dan
I have both wheels now. As stated above, the PT CPU work with both wheels but it seems I have to go through the relearn process to switch between wheels (rather than just find). This is a bit of a hassle, especially going back to the non-+ wheel (takes a long time to relearn). If I upgraded the SL with the Saris upgrader dongle to ANT+ would switching between hub be easier? Could I just have the CPU find the hub? When a hub is upgraded does it change the wireless protocol from Saris whatever to ANT+? Is ANT+ superior compared to the Saris signal when using only the PT stuff (no Garmin)?
