Hed won’t do it and the spokes will not line up, you will have to re drill a hole or two in the carbon fairing to allow the spokes to line up with the drilled holes in the rim and in the PT hub.
When I had the wheels built this was the response from HED
We can build your wheel with a PT wireless hub. If you want to do the hub at a later date be sure to have us build the rear 2x/2x. The stock lacing is 2x/radial but that won’t work on a PT hub. -Andy
Is the SL+ (bigger axle and lighter) worth the extra?
rock on…good call on your end…i bought a Jet 90 last summer with the intention of putting a PT on it later on…as i was ready to do i found out that the it couldn’t be done etc etc etc…wheeelbulder said they can do it and just have to drill a hole or two in the carbon…costs about 200 they said…was going to do it but decided to get a new C2 wheelset with a PT… i will remember that in the future about the 2x/radial lacing…so for all interested the Hed Jet 90 will go up for sale in the spring when i get back…its with the stock blue stickers…did one sprint on them…good luck with your new kit
I don’t know about the axle, but it’s around $14/gram to shed the weight. That’s a LOT to pay for gram-shaving. I personally draw a hard line @ $4/gram, and I’m a self-admitted weight-weenie.
According to wheelbuilder.com: The pro axel has alot of flex, not so with the 15mm SL. They recommend the Elite axel in the pro hub, if you go with the pro for a training wheel, and not the SL. That is most likly what I will do.
The weight of a 24 hole SL+ hub is 425 grams (heavier than PT advertises). So it’s probably even more $/gram than you say (assuming the Pro+ weight is advertised correctly- which I doubt) Their old 2.4 hubs were on average approx 427 grams. I’ve weighed 1 of the new SL+ and 3 of the older ones- 2.4 wireless.
I was told by my wheel builder that they have been less than impressed with the SL+ bearings. I was informed that I would need to replace the bearings sooner than with the PRO+. I don’t know if this is true…just relaying some info.
