Powertap data mishap - help
I am having a bit of a weird issue with the powertap. I have just changed all the batteries (hub and computer) after it was playing up a bit. Did a good interval ride last night, and have had a couple of goes at downloading the data. Each time I down load, the previous ride data is shown from a couple of days ago (3hr 47min, ave power 204). On the PT computer average power is 242 and time is 1:18. The ride last night was around 1:18, I would thing the average power would be 260-270, but maybe the easy was a bit easier than normal so 242 is possible for the average power.
The question is why is the ride last night not getting down loaded??? It is not tagged on to the end of the ride that is stored in the PT computer (and getting downloaded), and 2 separate rides are not getting down loaded. I have tried with powertap link and power agent 5 software and both are down loading the same data. I am quite keen to get the data out of the PT computer before my next ride!!! Any thoughts? I cant use the power agent 7 software as I have a serial cradle and that is not supported with the new software…
Help…
If you have a standard: http://david256.com/power/ptrescue/
Did you remember to clear the previous ride from the PT?
If using Cyclingpeaks,
1. Does the PT download show 2 workouts in the download window?
2. You may be looking at a selection, not the whole ride.
It is the powertap SL (thanks klehner).
Not sure I did actually “clear” the previous ride, but the time/distance was showing 0 after replacing the batteries, before I started the latest ride. I am definitely not viewing only a selection of the ride, and there are not two rides listed. If I had not cleared the previous ride - the new ride should be at the end - surely. I have not cleared the data previously and the rides are joined…
