Powertap and HRM - Bike to run
I have a Powertap on my bike which the non coded chest strap. I then use a Garmin on the run which uses a coded chest strap. Even if I use primarily power and pace, I like to check my hr. Which solution do you propose?
Change strap in T2? Get a cheap non coded HRM to keep on the bike and on the run?
Thanks
i recently got a power tap as well and was wondering the same thing. Once off the bike, do i then switch in T2 to another heart rate monitor?
Wasn’t aware the Powertap was non-coded. Just read the manual (interesting concept!) to see you’re correct. Strange thing is … my Polar S610 actually picks up the PT non-coded strap! Bless that HRM … bless it!
Yes, you need a cheaper non coded polar. I think they only make 2 non coeded now.
Thank you for the answers.
It looks like Polar accept non coded strap whatever the model is.
I am going to check with my wife’s Polar.
I believe I wore my Polar strap on the bike and run. My Powertap picks up the Polar signal most of the time. Even if the Powertap is not picking up the signal, I have the Polar watch on and can check it if necessary. On the run, I use the Polar watch with the Polar strap. I do not know if this setup will work with a Garmin but I thought I would offer my experience with Polar/Powertap.
thanks for the tips. does anyone know if the Polar s625x would work?
It does not. You must go with a cheaper HRM during the race. I’m in the same boat with the 625x.
I use my Polar S7201 strap and the PT picks up the signal, then I wear the polar watch on the run. Sports Instruments makes the PT chest straps. When my PT strap broke, I bought a cheap sports instruments HR monitor for $15 and use the strap with my PT. http://www.sportsinstruments.com/products.html
thanx XXX, that sux but whatever. appreciate it
