Quick question…downloaded all data last night then used Poweragent to clear the head unit as always.
Riding today it flashed “FULL” on the bottom row about every mile. When I went download today’s data there is none?
What does full mean? Does not show that term in the manual.
Thanks ST as always!
TriToy
2
I always clear directly on the unit head as poweragent clearly does not always do its job…
Thanks…how do you do that?..I followed the manual instructions and it only seems to go to another interval? I dont see CLR??
Khai
4
You put out too much power, hence it gets quickly full.
TriToy
5
hold both buttons simultaneously until -clr- appears then let go
Thanks I was just pressing them and releasing which does interval…I guess I missed the HOLD part!
TriToy
7
if you keep holding you get to the menu to change settings - including having your PT be coded to your garmin HR strap…
