Powerfile with no duration
Is there a quick fix to a bad/corrupt power file? I’ve downloaded to poweragent and had two rides. My 85 min or so ride was broken into two rides, a 1:10 ride and a ride with 0:00:00 duration and no other data.
I merged the two rides and open the ride in excel. The duration goes from:
70.65633 2.04E+08 2.04E+08 2.04E+08 2.04E+08 2.04E+08
This happens occasionally, couldn’t find a solution via search but thought i remember seeing this in the past.
What did you record it with?
Sorry, Little Yellow Computer
Hmm. Are you saying that one ride was broken into two pieces without you doing anything? I do know that if you hit the start button before the head unit finds the wheel it won’t record correctly.
I stopped to fill a water bottle…happens when I stop for a couple of mins. I usually just merged the two bits and I’m good.
Will probably email cycleops
Could be you inadvertently hit a button to auto lap when stopped after a certain amount of time but then didn’t hit the start button again for the new lap. I doubt your corrupt file can be fixed though.
It recorded the torque, cadence, watts, its just the duration column that is jacked up…but thanks for the bumps :slight_smile:
