Possible Bike build upgrades: what takes priority?
So got a TT bike that I love built with SRAM Rival and profile design Ozero bars and and alloy clip-ons. I was wanted to make a list of possible upgrades and prioritise them considering Christmas is rapidly approaching so my better half might be able to contribute!
What woud be your priority
Last year I got Aero lid and SRAM S80 wheels also own a powertap and an aero-disc cover.
List of possible upgrades: (feel free to add this all I could think of)
Garmin 910XT as bike and run computer
Rotor Q ring TT chain rings: do they work sounds like a good idea. if so what ratio?
Carbon integrated aerobar are they better?
aerodynamic brakes
sRAM Red front and rear derailleur upgrade (dont know if it makes much difference in a TT set up
Aero Chain rings FSA or the like?
SRAM R2C shifters
Any other suggestions? need to capitalise on the upcoming christmas
Christmas…? It’s halfway through October. Don’t depress me.
Having said that they were playing Good King Wenceslas in Woolworths here on September 6th.
To the OP - a set of Simkins brakes should be on your list, not that I really care with all the bloody goodies you have already. And yes that is the annoyed ring of jealousy right there.
Simkins brakes not heard of much testing on them but they look slick! on the list they go! thanks
I know what you mean I just recal writing down my new years resolutions for 2011 and have not even started on them!!!
A new frame.
CompuTrainer.
Bike Coaching.
Bike Fitting Session (if you need it).
Those are the things I can think of that will make you faster. Everything else is just excess bling.
Q ring’s aero chain ring
none of that stuff takes priority.
the aero chainrings, maybe you save a couple seconds per 40k, and its cheap and easy to do with no downside so that would be fine.
the aero brakes - again maybe you save a couple seconds per 40k, but there are downsides in braking performance or hassle with wheel chhanges usually.
the rest, meh.
if you have money to burn you can start making the bike as light as possible, so SRAM red would help there.
SRAM R2C all the way!!!
As somebody that already has zipp return2center shifters, I would tell you not to waste your time or money. They are way too finicky.
Anything else on your list looks good though
A new frame.
CompuTrainer.
Bike Coaching.
Out of curiousity - why would a CompuTrainer make someone faster? He already has power, if he has a trainer he’s 90% to a computrainer. Add in well thought out trainer sessions and the money for a CompuTrainer would be better spent elsewhere, no?
To the OP: all the bling, as Nick called it, probably isn’t necessary/worthwhile/won’t make you faster. Depending on what watch you use now I might get a 910XT (or buy a 310XT, which has everything you need minus some swimming lap functionality) then invest in a good coach. Nothing will make you faster than a good training plan.
Upgrade the engine. Ride more.
how about profesional fit and good aerohelmet?
Did not mention but the bike was bought and setup with a professional fitter. Must say the best money spent.
I would also like to clarify that its not about money to burn I am just expecting a couple of Christmas presents and thought I could give the family some guidance as to what they can get!!
The engine… well I am working on that too. probably the worst part of the setup!!!
oh thats why i though aerohelmet is good - fits under xmas tree and one of the cheapest aero solution
…hey if it worked for craig will work for you!
My Zipp R2C shifter work almost perfectly and can make 3 cog changes with one shift if needed. I hate the standard shimano bar end shifters with the weird position angles.
Everyone is right. Riding makes you faster. But you can prioritize what you WANT on your bike. You don’t have to have a reason other than wanting it and having the money. For me, I like a good drivetrain. As someone that’s had lots of stuff, red is close to force. If your on a budget, do force. Do red just to have it.
What are you doing for hydration and storage? I’d get a cage for a between-the-forearms standard bottle, and maybe DarkSpeedWorks’ top tube aero bento bag.
Also low-Crr tires, latex tubes. Good home pump. Good fan if you ride a trainer. Aero skewers?
Want something more spendy? I read ST on an iPad sometimes when I’m on the trainer in the garage; have a little shelf set up for it or a laptop. If you’re a Mac house, then an Airport Express for powered speakers with remote control is very nice…
powermeter
powermeter
got one already
Torhans Aerobottle?
I have heard complaints about the Red FDs. It is a little flexy. I would use force for the front fd red is fine for the rd. Even the pros run force. I just bult a road bike with SRAM and love it. I then converted my tt bike to SRAM and I am equally as happy.
From the list I would go with the Q rings and if you have money to burn get them with the 3D cranks. I went with compact 170’s for long course training. Road bike has 175’s standard.
The best use of your money after that would be a good coach that will push you to/beyond your limits on the road. You could also find a good hill and do a repeat for every dollar that you spend on the rest of the aero gear.
