Pool water draining from nose
I’m just curious about this. I have some pretty f’d up sinuses from a bike crash years ago that moved my nose, temporarily, to a position directly under my left eye.
Since then, I normally have bits of pool water that drains from my sinuses off and on for the duration of the morning after a Masters’ workout.
Doesn’t really bother me, and I kind of like the eau d’chlorine, but wondering if anyone else goes through this. One day I’ll have it fixed, no need for a nose clip either - hate those things.
I get this also from time to time, for me its backstroke related. It doesnt really bother me unless i dont happen to have a tissue or something to deal with the dripage later on ;p. usually goes away a few minutes after my workout.
http://mud.mm-a6.yimg.com/image/3400204091
I don’t get that from pool swimming. I do get it with my open water swimming and surfing. When you get out of the water try bending over and blow your nose “easy” while turning your head from side to side.
Water in the nose is a good medium for bacteria to grow. So you might want to get it checked by ENT.
It has been happening for about 5 years now with no noticeable increase in colds/sinus infections. ENT? Crap, I’ve had it looked at by EVERYBODY. Surgery is my only option.
Do a search on sinus sinusitis. This is very common with scuba divers.
If you are not getting sinus infections (sinusitis) I would not worry about it. Water in the nose is very common with H2O sports. Kinda like getting wet…LOL:)
I get that from open waterswims too. When I bend over to dry off my legs it’s like turning on a tap! I’ll be sure to try blowing my nose whilst bent over next time.
Do it easy. You don’t want to push the water into your ears.
Wilco.
I’ve had the same problem ever since I began swimming a few years ago. Everytime I get out of the pool I lean over, blow my nose, rotate my head around etc… trying to drain everything out. Despite this I almost always have water drain out of the same side of the nose up to a few hours later. As a previous poster stated- its like a faucet turned on for a second or two. Any other advice if the basic lean over and blow your nose doesn’t see to cut it?
