Hey there…
Just curious what others have for zones… Mine are based upon a lactate test completed about a month ago: If it matters, I’m 6’2", 190 lbs, Male, 35.
Zone 1: 131-143
Zone 2: 143-155
Zone 3: 155-163
Zone 4: 163-175
Zone 5: 175 +
Hey there…
Zone 1: 131-143
Zone 2: 143-155
Zone 3: 155-163
Zone 4: 163-175
Zone 5: 175 +
Do you adjust your zones for running —biking----swimming??? I have heard you should and that they are the same. I know I have a hard time keeping my heartrate up on the bike. It seems I have to really work hard to get in zone 2-3 on the bike but I get there easy on the run
Just did a 20 minute indoor field test 2 weeks ago-
My understanding is that heart rate itself is not so important when benchmarking your fitness zones to other athletes. After all, it’s all relative to your maximum heart rate anyway. For example, someone could easily have a lower AeT (Aerobic Threshold) heart rate than me, but produce a lot more Watts at AeT. So, if you’re going to go through the trouble of getting tested, focus instead on your percentage of VO2 max at AeT and AT.
January 12, 2007 - Bike Fitness Test
Z1: 127-138
Z2: 139-149 (Aerobic Threshold. V02 39.5ml/kg/min or 55%max.205 watts)
Z3: 150-160
Z4: 161-170 (Anaerobic Threshold: V02 51.6ml/kg/min or 72%max.260-270 watts)
Z5a 171-174
Z5b 175-179
Z5c 180+
V02max: 71.5ml/kg/min
Compu-Trainer set at 2.15lbs
My Zone 2 heart rate was between 140 to 148 bpm (60% of VO2 max) when tested on the treadmill on June 2, 2006 (see below). My bike test done earlier this month showed that my Zone 2 is between 139 to 149 bpm (55% of VO2 max). I am told that your ‘zones’ should be at a higher heart rate for activities like running, cross-country skiing, and rowing. The fact that mine are the same could be because over 6 months has passed since my initial test–or–because I am more efficient at cycling relative to running. At any rate–I am told that I will be best served training in Zone 2 near my AeT. This will hopefully boost my percentage of VO2 max. within this zone and perhaps raise the heart rate at which I’m able to maintain Zone 2. I’m told that I should be striving to get my %VO2 max up to 70% at the top of Zone 2 (for IM distance training). My results indicate that I’m spending way too much time training above AeT and possibly above lactate threshold (LT). This fitness–while okay for a short TT–will not serve me well in my quest to complete an Ironman.
June 2, 2006 - Run Fitness Test
Zone 1 131-139
Zone 2 140-*148 Aerobic Threshold * V02 of 42.0 (60% of max)
Zone 3 149-156
Zone 4 157-165 Lactate Threshold V02 of 53.0 (76% of max)
Zone 5a 166-176
Zone 5b 177-187
Zone 5c 188 and higher
V02 max 70.0
I’m new to this zone thing and thought that there were only 3 zones?? zone 1) being slow with HR below 140 bpm.
zone 2)faster at 140 to 165 bpm.
zone 3) fastest, above 165 bpm and up to your max?
Can a person really tell the difference between Z3 and Z4a,4b or Z5a, Z5b etc…???
MOP Jac
Seems high given that the same zones for running will generally be 10-15 beats higher. You must have an unusually high max HR.
If I was traing by HR my zones would be:
Zone 1: 108-131
Zone 2: 132-148
Zone 3: 149-154
Zone 4: 155-164
Zone 5: 165+
As set forth by the Tri-Geek Spreadsheet and Joe Friel
jaretj
Zone 1 - Recovery: This is the zone most commonly used during recovery between intervals, or on easy “recovery” days. Intensity is well below LTHR, and your engine is basically idling.
Zone 2 - Extensive Endurance: This intensity is most commonly referred to as conversational effort. Because endurance is most effectively developed and maintained by training in this zone, most long endurance training sessions are done within Zone 2. Exercise in Zone 2 is measured in hours. You are now on the freeway in 5th gear, turning 2800-3000 rpms and going about 75mph, making the long drive to Vegas.
Zone 3 - Intensive Endurance: Because it is neither aerobic (Zones 1 and 2) nor anaerobic (Zones 4-5c), this intensity does not effectively train either energy system. With the exception of early base training, if you find yourself in Zone 3, its is more efficient either move down Zone 2 or up to Zone 4-5a.
Zone 4-5a - Threshold: In this zone, your body is at its maximally aerobic state. That is, this is the fastest you can go and not be anaerobic. Because you are still aerobic, to a degree, you can maintain this pace for several minutes, thus exposing your body to high levels of lactate and maximizing the adaptive response. The needle on your tach is just to the left or to the right of redline.
Zone 5b - Anaerobic Endurance: Training in this zone increases the body’s tolerance of high levels of lactate. Because you can only maintain this effort for a few minutes, intervals are the most common Zone 5b workout. During interval training, intensity is maintained for a few minutes in Zone 5b, triggering an adaptive response. We then rest, allow the body time to flush out the lactate, and then repeat the exposure.
Zone 5c - Power: These are extremely short, maximum effort bursts of intensity. Their value to the multisport athlete is limited, with the exception of those severely lacking in force and power.
(Source: “Triathlete’s Training Bible,” by Joe Friel.)
http://www.cruciblefitness.com/etips/training-zones.htm
