Can anyone tell me how the POlar S625X actually works? The polar site says that it analyzes each stride using “advanced sensor technology”. What the hell does that mean? Does it simply pre-measure your stride and then work from there? My issue with this would be, what if my stride changes? How would it work then? What if I try to increase cadence and decrease stride length? Do I have to completely recalibrate it? I’m just not sure my stride is totally static.
People who use it, how reliable is it? How accurate? I have a Garmin, but I have been unhappy with it’s performance on smaller loops, and I’d like to have a HR function built in. So I"m thinking of going with the S625X with the power sensor on the bike. Thoughts?
it doesn’t just premeasure your stride thank god, that’s what those little cheapy pedometers do and for $350 the 625 better do better than that as you could get a free pedometer at McDonalds for a while…
The little foot pod that comes with the 625 is a small accelerameter which measures the acceleration and deceleration of the foot. Not sure how it does this, guessing a small piezo gyro or something. This is the same technology that both Nike and Polar license from Fitsense I believe. My Polar seems very accurate as long as it’s kept on the same shoe you calibrate it on. Problem is that I work at a shoe store and have ten kabillion shoes… Okay, so that’s not a real problem but it makes using the Polar a hastle. I feel like lots of hills sometimes throw the Polar off a bit but otherwise it works pretty well.
Is you altimiter psycho? Mine jumps all over the place even when I’m riding the trainer in the garage, or running on a treadmill. I just turned it off tonight because it’s populating my pretty graphs with garbage data.
I’ve never calibrated it of course, but I’d think that even then it would just be steadily wrong, not bouncing all over the place.
The altimeter can be finicky. Also, they use a lot of battery, so if you are training inside, it is best to turn it off anyway. I find the one on my S710i to be pretty good. The one thing I notice though is that it takes it a while to adjust to the temperature, so the readings at the beginning of a run are usually skewed. Temperature plays a big part. Putting it on your wrist will mess up the altitude, and then if you go from your nice comfy house, to a cold winter day for a run, it takes a while to adjust, and your alt will be skewed. Calibration just sets the current/starting alt., it won’t affect the accuracy of the changes in alt during a workout. The calibration will vary with the weather.
Thanks for the info, all of you. You mention the battery life, efernand, how long is it? One nice thing about the gramin is that it has a built in lithium-ion battery and comes with a charger. Do the separate parts of the polar have separate batteries? Are they rechargable or easily replaceable?
The battery in the watch lasts a pretty long time. I have had mine replaced once, and I have had it a few years.
Each part of the Polars have their own battery; the watch, the strap, the speed sensor, the cadence sensor. Polar recommends sending the watch and strap to them for replacement (the entire strap gets replaced at a reduced cost) to insure water resistance. People complain about it, but it only costs < $20 to have them replace the watch battery. It may seem like a lot for a watch battery, but it is a $200 watch, might as well keep it working right. The straps last a long time, just make sure you dry them off when you are done, and don’t put them in a bad with wet stuff. If you don’t break the electrical contact, you will run the battery down faster.
The speed, and cadence sensors you can do yourself, quite easily, and you can change the power settings on those while you are in there. (move the jumper) The sensors seem to go through batteries faster, especially when set on high power. The batteries are standard (cr2032 I think) and not that expensive.
I had the fitsense watch when it first came out. I had reliability problems with the overall system, but the distance/speed measurements were very accurate.
I ran down to the beach, about 4 miles, then reset the altimeter to about 10 ft.
Yesterday I did a 4.5 mile out and back run on a slight incline and my watch said I climbed 780 feet. Yup, pretty whacky.
The big problem I’m having, though is I download the data and the graph fro the last exercise appears. When I go to the dairy to add other info, the graph thumbnail is blank. I use the attach button and select the heartrate file and nothig happens. I tried opening the HR file and the graph comes up blank. Earlier ones from December open fine.
I looked at the file in a text editor and compared it to a file that opens properly and, other than the actual data, the file structures are identical.
The watch battery is claimed to last 2 years but I’m guessing more like a year and a half tops if you use it a lot. You can do the replacement yourself but it’s not worth it if you have a 710, 720, 625 model. One, they have a 2yr warrantee so you are probably voiding that, two the damn battery (this HUGE lithium cell) retails for around $10 if you can even find it… Send it in for about $12 plus shipping and they do it for you in a week or so.
My altitude has always been pretty steady and accurate. If I do a lot of climbing I’ll check it with a street side altitude sign (they have those when I go home to train) and the altimeter is spot on the rest of the ride. I’ve owned a 710, 2 720s and now a 625 and they all worked great.
The 625 is great but I swear the battery in the foot pod dies waaay to fast.
I have had the 625 for several months now and I have no problems with the speed function. Once I calibrated it, it seems to be pretty accurate, even after I changed shoes. I did it on a track, not a treadmill which in my opinion is better. I have a variance of .1 miles over three miles on a treadmill.
The altimeter is useless. I have reset it a million times while standing on a floating dock and its goes crazy even when I have gained no significant altitude. I don’t think I have turned in on after the first week
Question: Is there a way to get the recovery function to work in Basic Use Mode? I can get it to work in an Exercise Set, but in Basic Use, it won’t work. My 610 works in Basic Use so why won’t this model?
What do you mean by “it goes crazy”? Does the alt change significantly while you are watching it, or over a few hours? Or does it change day to day, week to week. To be correct, the altimeter needs to be reset every day, or each time you want to use it. Since it operates on barometric pressure, changes in the weather will alter the readings all the time, even during 1 day if a system is coming in.
What I mean is that if I reset at water level and then go for a run around the beach, it will read something like “780 ft”. I can tell you that there is not 7 feet of hills at this spot, let alone 780 feet of altitude. I hear what you are saying about baro. pressure day-to-day, but this happens on the same day.
Anyway, it’s not that big a deal to me since I am not concerned with how much I climb in a given day. I just thought I would relay my experience.
