Polar speed and cadence with cervelo p3?
curious if it works??,put on downtube??accurate? do i need cadence if im a tri guy? i need a new polar…old one s210 broke…tia
Where there’s a will, there’s a way.
It’s accurate. One issue is that you can control the transmitter strength if it is very far from the watch mount. The other issue is that Polar supplies a crappy weak magnet for the cadence mount on the crankarm. No one needs cadence, but if you want it, why not. The little cadence and speed sensors sort of cancel out some of the frame aerodynamics you get from a Cervelo. Depends on what’s important to you.
I find cadence in valuable on my P3 - have it on my down tube.
I’ve got the speed/power/cadence on my P3 and it works just fine.
-Colin
