Polar S710 i question
I’m not able to delete files, and clear the memory (memory is full). I am holding down the delete files buton and it is not clearing. Any thoughts? What step am I missing. The handbook steps are being followed I think. Thanks in advance to any one who can set me straight.
I have the same problem. Every time I use it flashes that stupid memory full at me. Not that I’ve put any effort into trying to remedy the problem.
I used to own one. You get to the Delete files question and then press the other button to say yes. Is the yes button working? The other option is to you the IR connection and clear it from your computer IIRC.
I try that but nothing happens.
So it never asks if you are sure?
If it does not verify that you are sure, it sounds like the OK button is not working.
you go to the file you want to delete (upper right button then red button)
hold the upper left button until it asks you to “delete file?” hit the red button
it will ask you - are you sure? hit the red button again.
do the above until you’ve deleted all the files you want
You may have to do a Global Reset. I forget the exact procedure (email polar, they’ll send it), but it includes pressing the little button on the side.
This is the method I use and it works everytime.
I use the same method.
Have you tried connecting using the IR software to your PC and deleting the files that way?
