CCF,
I just got one of these watches - to my surprise, it isn’t too ‘tri’ friendly. For individual sports (training), I love it. Do a tri… Don’t know yet. I wasn’t too happy to find out you will have to stop the watch at each ‘transition’ and start a new file. To figure your race time, you have to do addition… my brain usually isn’t too far behind my body - I can’t do much addition when I’m cook’ed.
To your questions:
I assume you set up bike functions correctly - the thing must be broken. The watch has two bike setups - when you switch back to ‘bike’, are you getting the correct one? Easy test - set both bikes up the same, that way either will work.
For the distance on the road, make sure you are looking at ‘distance’ and not ‘trip’. If you are looking at the correct one, well… the thing must be broken. Do you save several files on the watch-then download or do you do one session-then download (possible to get one of the exercises mixed up?).
If you got the watch at a good LBS, talk to them and possibly try a second watch to see if it is the watch or the user. For the user - they might be able to help or just call polar.
Climb1mt
Colin,
I’m not quite sure why you are experiencing the differences you mention in item two, but I have experienced what you are explaining in regards to the bike 1 setting. You might want to consider checking out the yahoo group for the s625x. There is some pretty good information to be found there. Anyhow, this is the fix to item one explained:
http://health.groups.yahoo.com/group/S625x/message/969
“I spoke with a more knowledgeable tech who reccomended I reset the device- it worked- no more problems! Here are the instructions:for the default reset just press the reset button, then left lower and upper right one after another, then upper right till you get to default set. then hold the red button till you get back to time of day.”
Cheers,
Colin
