Polar infrared USB adaptor HELP!
For those of you using the polar devices with infrared upload functions to a computer, have you managed to get it to work with any brand of IrDA USB adaptor other than the Polar-branded one?
Mine works fine with the IR on my Toshiba M400…that help?
I got one from Amazon.com. It was a lot less than the Polar. It was also listed as a accessory for sale if you bought a polar. Go to Amazon and search for polar HR monitors and it will come up. I think it was a Star Tech or something and it says it was ROHS compliant.
Works great with my 725.
So feel free to ship it to Europe!
Yes. (That’s a link if it doesn’t show up as one in your browser…)
I uses the built in Irda port on my laptop, but have found that I need to be in a room that doesn’t have a lot of direct sunlight or have other infra-red devices being used for it to connect and work properly.
It depends on which Polar unit you have. I had to buy a usb/IR device for my CS600, since my home laptop doesn’t have na IR port (my work one does - unit works fine with both). Now what you have to realize is certain units require the Polar unit, and that is a proprietary IR interface (it does not conform to IR 2.x standards) - and those puppies are pricey. So make sure you have the correct interface for your unit.
Other than that, it is usually just a line of sight issue - took me a try or two to get it lined up and recongizeing the first time I set it up. I alos found one setting on the polar software worked a lot better than the other - would have to check again and see what that is.
My laptop has one built in, so I would imagine it would work with any brand.
