Polar GPS G1 support to S625x (calling vvarta)?
Hi!
Anyone know WHEN the GPS G1 that can switch between Mode1-2 was discontinued? Is there a serial number/ batch no. that can be used for ID?
Different product modes with Polar G1 GPS sensor
Polar G1 GPS sensor has two product modes: mode 1 and mode 2.
Mode 1 is used for a limited number of G1 GPS sensors compatible with Polar RS200, RS400, S625x or S725x. This edition of G1 sensor is no longer in production.
Mode 2 is used when you use G1 GPS sensor with Polar FT60, FT80 and RS300X.
To change between Mode 1 and Mode 2
  1. Activate the sensor.
  2. Press and hold the button for the duration of ten battery indicator led flashes.
  3. G1 satellite indicator led flashes four times as an indication that the mode is changed.
