I currently own the 625x, I really love it except the fact that it is huge. Anyway, are there new things in the works or is the RS800SD the new kid on the block… I see there’s an added cadence reading… is it a step up?
advantages of the new RS800sd-
-cadence readings, with options to identify stride length per parts of your run
-(WIND) transmission-working off 2.4Ghz, giving it no interference from outside sources (power lines, etc), BUT it will not pick up underwater.
-Improved software to upload workouts on your watch.
-2 way communication between foot pod and watch. THis means the foot pod turns on and off automatically.
-Next generation foot pod. It’s quite small. ABout the size of a half dollar.
If you want the Top running model. It’s the 800sd, BUT it does not have the options for bike mode, like the 625 has. If you want to wear it in the water, go with the 625.
Let me know if you have anymore questions.
Eric
Just when I thought I was finished buying new toys:)
So I would assume that there will be something like this with a bike interface in the near future?
Do you know if the software is simular in format to the 625x?
It has the new Polar Pro Trainer 5.0 software for the 800sd. As far as i’m aware, the 100, 200/sd, 400/sd have replaced the 120,150,210and 610. The only ones left from the original S series are the 625 and 725. So i don’t think there is any upgrade in that bike feature in the near future.
Eric
