Polar 720si users, help
I lost my manual and can’t seem to erase past workouts. the watch reads “memory full” when i attempt to use the hr function. help, please.
Hi, I think I can help?
Go into FILE, Press and hold top right/light button, Delete File#?, red button, are you sure?, red button. and so on until empty.
Or do it via your computer once downloaded.
Also the Polar website has PDF copies of the manual.
Cheers, from a lovely Christchurch NZ day, Scott
cervelodude,
This is my 1st time posting:
  1. Hit the upper right button until “File” appears.
  2. Hit the red button
  3. Hit either the upper/bottom right button until you see the workout that you want to delete
  4. Once you’ve done that, press & hold the upper LEFT button until delete appears
  5. “Are you sure” appears, hit the red button if you want to say bye-bye to the file.
Peace
As scott said. The manual is online: http://www.polarusa.com/manuals/S720i.pdf
page D73 and D74 cover deleting files…
It can also be done while linked up to their software if you are using it. This is a much quicker way to do this either for all workouts, or selectively.
