Please critique my position... (1)
I’m sure I’ll regret this, but the pain in my manhood is worse than the humiliation I might get on my ego. On Saturday for my TT, I had some discomfort in my left hamstring. A ride of two before that, I had some soreness in my left crotch area. I’ve never been comfortable in the saddle I got; I just thought the saddle needed to be broken in.
So, on my easy trainer ride this PM, my left hamstring, that was feeling better since Saturday started feeling agitated, so I stopped. I’m thinking there’s some fit/set up issues that I’ve got.
So, I’ve created a picasa account, in hopes that I set this up so folks can see the pictures and give me some feedback. I’ll start it off…my seat’s too high.
http://picasaweb.google.com/mpalios/Desktop?feat=directlink
Thanks for any help.
I find with eye line the best pictures are outside, try that and re-post. I BET you a ton you will be happier…
Wait a second…could you see the pictures? I can, but that doesn’t count because it’s my computer. if you can’t see them, I have to figure out how to do this.
You look soft, train more and loose some weight. I bet you will go faster then
People, please do not post shirtless pics, especially when you have the same physique and fat percentage as a sausage…
I seen them fine, just talking from experience. I took a bunch of shots and was not impressed, went and raced a TT and had the wife out there taking pix and a pro photographer. I was like WOW, i gave my self a A- at race speed and a C- inside pedalling on the trainer.
coming from a guy named chubbly, I’ll take my chances.
And with a shirt, you might miss some angles. Now, if you’d like to help out my position, please do so. If you want to rip how ‘out of shape’ you think I am, take a pass. No need to be a 110% complete asshole.
WTF is wrong with you!!! stop eating so much and for f*** sake wear a tri top or cycling jersey. You are one of those shitheads who walk around naked in the gym!!
In case you were wondering, yes I am an elitist prick! Now get off ST and back on that bike
First off, please ignore Chubbly. I’m not sure how he has not been banned yet, but we can hope that event might come soon.
Some general thoughts–the adamo is not for everyone. I thought it was the most uncomfortable saddle I had ever tried. Others like it. Try something different. I went through a lot of saddles before I settled on the one I am using now. If you live in an area with a lot of riders then just ask around. I have two or three saddles lying around and others may be able to loan you something else to try.
If you really think your seat is too high then drop it 5mm and ride around for a bit.
Your position has almost no drop so you ought to be comfortable enough to ride it all day. If you want to go faster then you will need to get more of your chest out of the airstream by dropping your front end until your back is flat.
Chad
What are you training for? If its IM than if thats the position you can hold for 112 miles okay.
But if its an Oly, you look way too high to me. Need to increase your flexibility and get your chest parallel to the floor.
That’s my .02
incorrect on all counts.
Chad
Thankfully, my nads hurt more than my ego, so chub’s dumb comments just bounce off my apparently fat stomach.
What does “no drop” mean? And I never thought it until I saw photos…I look very high up front.
To the poster just below cdw, I’m prepping for an Oly in October. I thought the guys I got fitted by were really good (in St. Pete), but now I’ve got to find another fitter in the tampa bay area to get re-fitted and a new saddle. Again.
Take a look at Wiggins, low and narrow.
http://i31.tinypic.com/2ujtx81.jpg
Not that you should necessarily copy the pros, but you’re way too high for an Oly, unless you have back problems or something of the like.
btw—I’ve posted shirtless pics for the same reason you did and got ridiculed by jackholes too.
Wiggins doesn’t have to run off the bike…
Sorry, too much lingo. Drop refers to the difference in height between your saddle top and your armrest tops. Just lean the bike so it is level and measure from the floor up, preferably in cms. Generally speaking, 5-10 cm is a pretty relaxed position, 10-15 more aggressive and 15+ would be a solid time trial/tri position. Now, I say “generally” because everyone has different sized proportions so what might yield an upright, non-aero position for one might make another pretty aero. I have pretty long arms and found that my best position was about 18cm of drop. Beyond 18 either did not make me faster or actually made me slower past 22cm.
And easy way to fix the aero position is to set your bike up in front of a mirror. The more your front end drops, the less of yourself you will be able to see and the less wind you will be pushing with your body.
People will tell you to go pay for a fitting, but this stuff is not that hard and is mostly trial and error anyway, even if you did see a fitter.
Chad
So what?
Chad
But, it isn’t just a simple case of dropping the armrests and/or raising the saddle…is it? You do either/both, you need to bump the seat forward, correct?
Chad
your seat already looks close to your bars to me
*But, it isn’t just a simple case of dropping the armrests and/or raising the saddle…is it? You do either/both, you need to bump the seat forward, correct? *
Generally, you can imagine each of your points of contact as a spot on a circle. Since the BB is fixed then you adjust around it. So if you drop the bars then the seat will normally need to go forward and up to compensate. However, there are some tradeoffs you can consider as you become accustomed to your position. If you drop your bars but leave your seat position the same you will increaset he distance from saddle to armrests and thus stretch out your arms some. I have found that moving the arms from being a verticle pillar to more of an angle helps my speed/aerodynamics. If you ever say the Obree/Boardman superman position they used for their hour attemps then you understand the idea. Mine is not so extreme as theirs, but I am pretty stretched out. This compresses the hip angle some and requires a good bit of adaptation before you are comfortable riding at power.
In your case, you probably ought to start searching for some new saddles to try and perhaps remove a spacer or two from you stack under the stem. Done over time and with patience your body will adapt and you will be more aero.
Chad
I have the adamo, and I don’t think you are using it right. You need to be sitting on the front of it, with your balls in front of the seat, not resting on the seat with them. Look up the link on google. YOu can find it somewhere with a picture. I will say that you also do not look comfy on your bike at all. I DO NOT think you need to drop your saddle, I think there is a lot more to your fit that needs to be done, but that is me, and I am not a fitter. Just my personal opinion.
Good luck. Let me know about your seat adjustment if you aren’t sure what I mean.
