I’ve picked up plantar fasciitis (for the first time - I’m 54 years old and have been running since forever). I’ve been running through it for a few weeks, but everything I’ve read says to quit running for several weeks/months. I’ve got it in my left heel. Does not appear to be going away. Hurts pretty bad in the AM, but I can run on it OK. I just ordered some new Hoka Bondi’s; thinking my current Bondi’s are pretty pounded out at this point. I’ve been running @ 25 miles / week. 1 short, 1 medium, 1 long run. I’d greatly appreciate advice or guidance from slowtwitchers on this. Thanks!
Tape it.
Keep it taped all the time for a couple of weeks.
I had it in both feet in the last five years- and I can say they both are totally healed. Went to PT where they did ultrasound and massage. Lots of stretching. Cut back on mileage but kept running. Iced it after running. did night splint for a while. Used arch supports in all my shoes. It takes a good six months to really heal. It’s two steps forwards one step back for a long time.
i have had it for nearly 12 months on and off and have still not sorted it
i honestly believe there is no absolute cure !!!
it will leave your body when its ready
its driving me to beer ![]()
keep away from HOKA
keep away from HOKA
Can you elaborate on why staying away from HOKA is advisable?
I had it bad training for my first IM. I tried all the home remedies while continuing to run, but ended up having to take 3 weeks off while starting both ART and EPAT. I then started back slowly, and while some pain was still there, it was more manageable and got me through the IM. After the IM, I took 2 months off running completely, started back slowly and haven’t had it since (4+ years).
I run 5-6x week and only wear shoes with some support, currently Hoka Arahi.
Good luck with yours.
I started wearing running shoes to work (instead of nicer shoes without padding). That helped a lot for me during the day. I also lightened up running for a bit.
I tighten up when I stop running, so I would advise against halting unless your pf is especially acute. Dialing back the distance for a while is reasonable. Perhaps consider knocking your long down to a medium, your medium to a short and adding a short if you can manage four runs in your schedule to keep your overall volume from falling too much. Your worn out shoes combined with age probably precipitated this. By all means begin using your new shoes, and make sure they provide good support. I am not familiar with Hokas so you need to do your research there. A year or two back my ortho, an avid runner, suggested Bondi 5 when I saw him for pf, so you are probably good there. Work diligently on staying stretched. Especially focus on stretching your calf muscles against a wall and off the edge of a step several times daily. I found a link on one of the pf threads in this forum to a youtube video in which the guy performed a scraping procedure with the lubed handle of a big box wrench against his plantar fascia. I did that a few times and found it helpful to a degree. There are night boots/socks that keep tension on your calf muscle and down into the pf at night. I’ve experienced both good and bad from using those, so I would advise easing into using them if you decide to try it.
Time and patience, you will work your way through it. Best of luck!
Chop your foot off, it is the only way.
Really just take time off combined with rolling your foot on frozen water bottles and golf balls, and other massage forms. Also stretch and consider attempting to sleep in a splint sock. Then when it does not hurt any more, take another week or two off and give it a whirl.
Wow. Thanks for all the advice. I want to make sure it does not get worse. No big races coming up, just a sprint in a few weeks, so I’ll probably ease off the running after that and just ride and swim mostly. That’ll cost me, but hopefully I’ll be better in time for a big race next spring. Patch, patch patch!
Last time I had it I tried the Strassburg sock, rolling my foot with a golf ball, etc. None of it really worked. I settled on stretching my glutes, hamstring, and calfs, did eccentric calf raises, and was always wearing supportive shoes. If I got up in the middle of the night to go to the bathroom I put on a pair of running shoes. Avoid wearing shoes like thong flip flops or sandals.
Work the calfs a lot. Here’s a good video from a buddy’s business and he’s an awesome triathlete also:
Calf work, stretching and acupuncture/dry needling can all be very helpful.
I’ve had a couple of bouts of it. The Strassburg sock works pretty well…knocked it out on my first PF experience. The 2nd PF experience lasted a lot longer. Working the calves, dry needling, the sock, Superfeet inserts (I use the blue ones) in my running shoes and some “wrench” work knocked it out the 2nd time. I’m not kidding when I say “wrench” work. I saw a video of a guy using a standard double-ended wrench and running the handle part of it up and down his calves to work out the kinks and knots. He also used it on his heel and arch. I tried it and I think it helped.
The taping works but you have to use the right tape. Go on YouTube and search taping for PF and you’ll find many. The tape you need is that standard white medical tape but the kind that has no stretch in it. The taping will allow your tissue to repair itself without doing more damage. The problem with PF is you are always doing damage. Because you are always on your feet.
I heard something from a stand out triathlete (he’s 72 now and no longer racing but he ruled age group racing for almost 20 years) He told me recently that his sports doctor told him to keep Advil in his system for 1 week straight. He said it worked great. I hesitate to say this because I’ve never done that but because it came from him I trust it.
Hoka’s are 4mm or 5mm drop depending on the model. With PF you want to go to a higher drop shoe. If you’ve been in 4mm then 8-10mm shoes. That will help alleviate some of the strain & may lesson the symptoms.
I fought it most of 2017. Without writing a book: I reduced my weekly mileage to 30 mpw. I gave up on lightweight training/racing shoes. I dumped Altras, Sketchers, and Hoka Cliftons… and went to Hoka Bondi 5’s and then 6’s with double insoles. I wore a boot every night for about 8 months. I only ran on on an indoor rubber track, or occasionally a treadmill. I upped the interval work on my indoor bike trainer to stay fit. By the end of 2017, the PF was gone, and I was back to running outdoors. It hasn’t returned. I’m not messing around with shoes, and staying with Bondi 6’s, even for racing. I’m not increasing my mileage, and staying at 30 mpw. I’m having fun again, and back to winning age groups awards again. I even ran a BQ marathon this spring.
That’s interesting because switching to Hokas is what brought me relief from my PF. Goes to show there is no single magic bullet to fixing it
Chop your foot off, it is the only way. .
x100
PF since October 2017
Don’t use it any more. When it is gone, then get a PT.
Goal: Sept 1, 2019
To be continued…
I had it and asked around for treatments. Ice, golf balls, strapping, inserts, rest etc etc until a doctor told me you can try all of that but it doesn’t matter what you do it’ll take 2 yrs until its gone. The good thing is that it’ll take 2 yrs to go through all the remedies.
